Escos oil query!
Old Feb 11, 2005 | 02:48 PM
M.A.D.RST's Avatar
M.A.D.RST
Default Escos oil query!
The oil gauge in an escos is it suppose to stay still? Ive just noticed today that when you are at idle in drops to the bottom(red) and then once you are on the move it goes up and stays about centre!!
Is this normal???
Old Feb 11, 2005 | 02:53 PM
Cossie-Iain's Avatar
Cossie-Iain
Yes you need oil pressure on the move.If you have no pressure then theres something terribly wrong mine sits just above the red at idle.
Old Feb 11, 2005 | 02:54 PM
M.A.D.RST's Avatar
M.A.D.RST
Phew cheers mate.
Old Feb 11, 2005 | 03:28 PM
CabrioTurbo's Avatar
CabrioTurbo
if it drops in the red id worry.. at full chat it should be quit high though
Old Feb 11, 2005 | 07:00 PM
furry's Avatar
furry
DECODING JIBBA JABBA!!
totally normal buddy
Old Feb 12, 2005 | 08:38 AM
DaveEscos's Avatar
DaveEscos
should be on 4 bar + from cold start up
once warm, driving over 3000 rpm should be up to 4 bar
on idle an around 1-2
should NOT drop in to the red!
what oil are you using?
Old Feb 12, 2005 | 05:30 PM
M.A.D.RST's Avatar
M.A.D.RST
Millers
Old Feb 12, 2005 | 05:43 PM
DaveEscos's Avatar
DaveEscos
millers what?
10/40?
10/60?
Old Feb 12, 2005 | 05:52 PM
3drstretch's Avatar
3drstretch
If your using millers it should be the 10/40 XFS
Old Feb 12, 2005 | 06:11 PM
Graceland's Avatar
Graceland
Team HOTHOT!
XFS?
u not mea CFS
Old Feb 12, 2005 | 06:24 PM
3drstretch's Avatar
3drstretch
No XFS.You just paid more for the same stuff.
Old Feb 12, 2005 | 06:25 PM
Graceland's Avatar
Graceland
Team HOTHOT!
i aint bought it yet - i cant find XFS on the website tho - you got a link?
Old Feb 12, 2005 | 06:30 PM
3drstretch's Avatar
3drstretch
Sorry it is 5/40.
http://www.millersoils.net/index2.html
Click automotive oils and petrol engine menu.
Old Feb 12, 2005 | 06:33 PM
Graceland's Avatar
Graceland
Team HOTHOT!
cheers m8y
always thought that 5/40 maybe a bit thin tho
Old Feb 12, 2005 | 06:40 PM
3drstretch's Avatar
3drstretch
Nah mate it will be fine.Have a look at wot the oilman on here says and he recommends around the same. But he doesn't do Millers and wont give a thumbs up or down about it.
Old Feb 12, 2005 | 06:44 PM
Graceland's Avatar
Graceland
Team HOTHOT!
lol - i use millers - was tempted by shell helix at one point, but heard some rumors about it been shite
the millers factory is just round the corner from me too - might see what discouns i can orgasmise
Old Feb 12, 2005 | 06:48 PM
3drstretch's Avatar
3drstretch
H ave a go mate BUT cant see you getting much as i have to buy in at least 100 lires at a time.
Old Feb 12, 2005 | 06:49 PM
Graceland's Avatar
Graceland
Team HOTHOT!
i can only but try - gotta be worth a shot aint it
Old Feb 12, 2005 | 07:02 PM
Paul Eggleton's Avatar
Paul Eggleton
When using Mobil 1 motorsport, mine would just drop into the red at idle. Changed to Castrol RS and then to MOtul and when hot it's a couple of mm above the red.
Oil pressure is related to revs, so as these go up your oil pressure should go up to.
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
