.63 exhaust housing
Old Jun 28, 2011 | 05:52 PM
Joe91's Avatar
Joe91
Default .63 exhaust housing
What is the next size down from .63? I'm worried that my engine will blow a piston again because of boost spike, I don't care about the lag because I like it but even with a rr setup and running omex 600 is there still a chance it will happen again?
I was also looking at the t3 upgrade thing on ebay that gives you:
A/R 60 Compressor housing
Backplate (T04B Style)
T34 Compressor Wheel
Is this worth buying?
Thanks Joe
Old Jun 28, 2011 | 05:55 PM
luke19790_3's Avatar
luke19790_3
did you bolt that turbo to a mfi without changing the fueling
COLEYST200's Avatar
COLEYST200
wot car mate
Old Jun 28, 2011 | 05:56 PM
luke19790_3
should be ok on a engine with efi if its setup correctly. think .55 is the next size down
what spec is the head and cam?
Karlos G's Avatar
Karlos G
Balls Deep!
.55 is the next size down but why do you want such a big housing, A .48 can just about make 300bhp what power are you aiming for and what's your full spec mate?
If it's mapped correctly you should never destroy a piston... doesnt matter what management your running!
If thats one of the cheapo chinese ebay turbo's then stay well clear.
Old Jun 28, 2011 | 06:14 PM
Joe91's Avatar
Joe91
Its a s2. And yeah i was running mfi and didnt get it setup haha
I have stage 3 head, newmans cam, omex 600, Fmic with twin fans, cossie injectors, exhaust..
But like i said i wasnt running omex etc when i did it so i wasnt sure if it would be ok when its all setup properly..
Joe
Oh and its not a cheap chinese one off ebay, its a t3 off a cossie just with .63 exhaust housing on it..Whats your opinions on the T34 upgrade pack? its from turborebuild.co.uk
Old Jun 28, 2011 | 07:42 PM
luke19790_3
guess lack of fuel killed the piston, if the ecu is mapped correctly with injectors the engine will be fine. just bit of lag
Old Jun 28, 2011 | 07:43 PM
Rogeyboy's Avatar
Rogeyboy
turborebuild.co.uk rebuilt my turbo to "stage 3" spec and its been fine... So they are all good! Can't help you otherwise tho, sorry!
Old Jun 28, 2011 | 07:47 PM
Joe91's Avatar
Joe91
good enough for me!
Old Jun 28, 2011 | 07:58 PM
luke19790_3
how much was the rebuild?
Old Jun 29, 2011 | 10:57 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
A T34 is too much for a CVH head on most engines. Obviously there is exceptions.
If you want a larger turbo than the 4x4 T3 Compressor wheel & housing, i would advise the T35 as it is much better design for our fwd setups than the T34 is.
I built a Fiesta ZVH with L6 greys and T35 with .63 and made 320bhp almost 10 years ago now.
Old Jun 29, 2011 | 04:44 PM
Joe91's Avatar
Joe91
Mmm how much do T35 go for second hand? might be worth investing if they are reasonable..dont suppose you know anyone with one?
Old Jun 29, 2011 | 04:50 PM
Versus_Creations
Ask me a question!
due to the fact that they are not fitted to any petrol engine its very unlikely, unless you find someone who has one i have built in the past for sale.
Old Jun 29, 2011 | 04:53 PM
J1mbo's Avatar
J1mbo
B1mbo
That made 320bhp with that inlet? Must have kept it rather rich?
Old Jun 29, 2011 | 05:01 PM
Joe91's Avatar
Joe91
Want to build another?
Old Jun 30, 2011 | 11:19 AM
Versus_Creations
Ask me a question!
Jim the same inlet has run over 400bhp on a ZT.
Old Jun 30, 2011 | 02:43 PM
J1mbo's Avatar
J1mbo
B1mbo
Through a bad learning curve I found out just how shit they were at 250 and just how good my own inlet is compared, the difference is huge and the cost of a custom I'd never run a standard one again IMHO!
Old Jun 30, 2011 | 04:50 PM
crazycage's Avatar
crazycage
is that the same turbo fitted to your black escort?
tankybaby66
Feb 6, 2016 02:24 PM
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
