help, no boost!!!!!
Old Feb 10, 2005 | 11:00 PM
wardi's Avatar
wardi
Default help, no boost!!!!!
i ave just ad my s2 rebuilt using a 1.9 bottom end,it also has a bigger turbo, -31, piper 285t2 cam k-n etc, the problem is there is no boost at all, the car hasn't been set up yet but i would of thought i wud be able to feel it pullin, n e ideas fella's
Old Feb 11, 2005 | 07:32 AM
james_birch's Avatar
james_birch
i take it if the car hasnt been set up then it hasent been run in! so wtf are you doin taking it over 3k and trying to get boost for?! it will only end in tears!! i guess the builder of the engine turned the boost right down on tha actuator to stop you blowing ya engine! either that or a boost hose aint connected!
But if its just been rebuilt then you should be canning it!
Old Feb 11, 2005 | 09:14 AM
bassboy's Avatar
bassboy
As James said really...you should really be boosting at all for the first thousand miles and then again until the car is setup...but reasons why you aint boosting are what James said and to go a bit further, the actuator might be sticking, turbo bolts might have come lose, is there a bleed valve on the car?
just to get ya started
bassboy
Old Feb 11, 2005 | 04:11 PM
AKRS1's Avatar
AKRS1
As james said the person who built your engine might have turned the boost all the way down. But dont listen to what hes says on the last line
Old Feb 11, 2005 | 06:06 PM
james_birch
what not canning a newly built engine?!
ok super man! you go rag a turbo engine an boost it up with mineral oil in!
Old Feb 11, 2005 | 06:08 PM
AKRS1's Avatar
AKRS1
James i was referring to your last line of your previous quote where you say "But if its just been rebuilt then you should be canning it!"
Old Feb 11, 2005 | 06:53 PM
bassboy's Avatar
bassboy
james...think you need to re-read what you wrote lol
bassboy
Old Feb 11, 2005 | 08:39 PM
mitchrs's Avatar
mitchrs
you too bassboy fella, you said after james 'you should really be boosting '??
lol
im confuzzled!!..........
Old Feb 11, 2005 | 09:43 PM
james_birch
whoops! ment shoud'nt!! .......dam N AND T keys dont like to work after the would should!
poxy dyslexic keyboard!
Old Feb 11, 2005 | 10:03 PM
wardi's Avatar
wardi
the engine has bin run in but havent had time to get in on the rollers,
Old Feb 12, 2005 | 12:56 PM
james_birch
so engine run in! oil changed to synthetic! fuel set up?
if the answer is no to any of the above "i" wouldnt be canning it!
edited loads of times cus i couldnt get the bold feature to work!
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
