turbo charging a zetec?
Asking on behalf of a friend with a mk5 escort 130bhp xr3i
He wants to know if it is safe to run a decompression plate,only looking for 200bhp
whats the pro's and con's of a decompresion plate?
Thanks for any advice
The ONLY major con with a decomp plate (if it's designed and fitted properly) is the standard cast pistons... the plate itself need never be a problem at all in itself, but the pistons will always be the weakest point on turbo applications...
A lesser point is that the plate makes for a somewhat less than ideal combustion chamber geometry due a fair proportion of the chamber then being in the top of the cylinder in effect - all squish effect is essentially lost.
But it's horses for courses (and piggy banks
), for 200 bhp (14-15psi boost) on a 130 base engine, there's no reason the plate method will not work quite adequately; just give due consideration to the thermal limits of the pistons, so don't go flat out, racing the world and his wife at 140 all day or it WILL melt.
Matt Baxter
Sep 16, 2015 08:30 PM
