Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
ford focus 1.6 zetec cambelt change
Old Jun 18, 2011 | 05:54 PM
tigre76's Avatar
tigre76
Default ford focus 1.6 zetec cambelt change
If anyone needs anymore info on this let me know as i recently replaced the cambelt on my ford focus 1.6 zetec 02 plate.
Please be aware that if your engine has the black top cover it has no timming marks on the pulleys or key ways and requires some special tools which includes a crank shaft locking pin and a plate to lock the two cams, otherwise you have no way of telling if the timming is right.
Also i found out that my cam sprockets were the plastic/bakelite type which can break if not losen or removed properly.
Another thing i had to tackle was the bottom pulley bolt, only way i could remove it was with a desent high impact driver which i borrowed from a m8.
Old Jun 20, 2011 | 04:54 PM
Bailes1992's Avatar
Bailes1992
How do you use the plate to clock the cams?
Old Jun 21, 2011 | 07:30 PM
tigre76's Avatar
tigre76
Hi, you need to take off the rocker cover and at the opposite ends of the cam shafts you will see two slots where you slide the plate into, your know when its right as the plate can only go in one way... but remember that the bottom crank shaft needs to be in place too, hope this helps
Old May 9, 2012 | 06:35 PM
mk2rstaff's Avatar
mk2rstaff
Old post i know but what tool do you use to loosen the tensioner pulley on the aux belt???
Old May 12, 2012 | 08:55 AM
Pete Focus's Avatar
Pete Focus
Do you mean to actually remove the belt/ release the tension? I used a spanner on the tensioner pulley and turn but quite strong and as you release the tension slip the belt off but you are best to draw a pic of the routing as when it comes to putting it back they are a nightmare to figure out the route, very long belt!!
Pete
JoeyBoyden
Jan 4, 2024 02:36 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
