Is it my actuator?
Im having strange boost problems. I have a lot of preload on my arm (about 9mm) and im running 12psi of boost. I turned up the boost using a bleed valve a quater of a turn and it's hitting 21 psi. I thought the bleed valve was at fault so i removed this and run standard actuator pressure. Its now 10 psi.
I have nothing inbertween 12 and 21 psi.
It was only loaded with the 9mm to get the 12psi. I understand it should be something around 6mm preload with a aftermarket I/C. The -31 isn't that old but i guess even newish stuff can fail.
depends on the make of the -31 actuator.
genuine garrett should be good for a couple of years, collins and the like tend to have weaker springs that lose their ability over time.
call to matt lewis will get you a new one though.
Without it you will only make actuator preload pressure, as you are.
I dont know why Stu suggested another actuator as it is doing exactly what it's supposed to if it's holding 10psi without problems?!
JK12
33
Apr 26, 2021 12:09 PM
