misfire!!!!!!!
Old Jun 17, 2011 | 04:28 PM
tay14's Avatar
tay14
Default misfire!!!!!!!
my s2 has been parked up for a couple of weeks jump in it last weekend and the cars started to miss,more at low down revs and fine at higher revs,then every now and again i would get to around 3000 rpm hold back like mad and sound like a subaru.
new parts fitted so far =
4x new plugs 071 ford
1x set of motorsport leads
new group A coil
new rota arm and cap
the cars running standard boost around 9psi with no mods,ticks over fine ,starts fine and no oil or fuel leaks.
still the car was the same,checked the timing and was slightly out around 6 btdc, set this to 12 btdc,i little better but still missing and holding back.when i got the new plugs i set the gap at 1mm,with the group A coil i was told to increase the gap to 1.1 mm,still no better.so i tried the gap down to 0.6mm .the cars alot better with only i slight miss at low revs but now pulls fine.could this be the sign of the dizzy failing? sending a weak spark?
Old Jun 18, 2011 | 08:15 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Chances are that it needs a decent setup and tune, if you have done what you can the best thing to do is take it to a good tuner. If you state where you are in the country im sure people will point you in the right direction.
Regards
Jano
Old Jun 18, 2011 | 10:38 AM
tay14's Avatar
tay14
Regards
Jano
iam near wakefield west yorkshire.theres no one really close to me ,motorsport developments is around 1 1/2 away as is norris motorsport, and thats abit far to drive the way the car is.
Old Jun 18, 2011 | 07:57 PM
Versus_Creations
Ask me a question!
In that case you need to search for a setup guide that will help you get it running in a better condition, this will allow you to take a steady drive to the closest place on your list, both will get the car running how it should.
Old Jun 18, 2011 | 08:58 PM
crossy2004's Avatar
crossy2004
knock sensor maybe or temp sensors does it only do it when warm under load
Old Jun 19, 2011 | 07:37 AM
tay14's Avatar
tay14
theres a slight miss on tick over now and agian,but it happens when the cars hot and cold.when driving the miss is at low down revs but not all the time.if you take a h/t lead off one at i time the car runs on 3 but all equal.the car drives fine when you get going.tried unplugging the knock sensor ,still the same.all so tried unplugging each sensor one at a time still the same.iam going to get a new dizzy on monday and try that ,if that doest work i will have to try to get it checked over some where.
Old Jun 22, 2011 | 06:48 PM
crossy2004's Avatar
crossy2004
i just changed my dizzy and rotor arm and still no different ive had car setup fueling wise three times this year but no rolling road so think its rollin road time im sick of not boostin properly could be down to cam wear though too
Old Jun 22, 2011 | 08:05 PM
tay14's Avatar
tay14
I've just fitted my new dizzy going to set the timing tomo and see how that goes
Old Jun 24, 2011 | 04:42 PM
tay14's Avatar
tay14
fitted new dizzy still the same,so i was thinking could it be a air leak?so i gave a small spray bit of easy start around the joints ect and the revs pick up when i spray around the throttle body,especially around where the shaft goes through the body and joins the the throttle linkage.the gasket looks ok could it be drawing air in though the shaft?
Old Jun 25, 2011 | 06:31 PM
crossy2004's Avatar
crossy2004
how did it go
Old Jun 26, 2011 | 06:16 PM
tay14's Avatar
tay14
how did it go
I've order a throttle body off eBay and a new gasket,going to try that next week. If that doesnt work I will have to take it some where to be checked over.
Old Jun 27, 2011 | 06:25 AM
crossy2004's Avatar
crossy2004
should of said i have a throttle body lying around somewere
Old Jun 27, 2011 | 08:37 PM
mat35's Avatar
mat35
have you tried art engineering (turbo tony ) near to where b&q and sainsburys
Old Jun 29, 2011 | 08:12 PM
tay14's Avatar
tay14
Just done a comp test not looking good they are all level, but around 80 psi.I think I there ment to be around 130 psi? I would have thought if it was head gasket/piston rings or a faulty valve ect it would be low on one piston but not them all. The miss is still intermittent with I slight blip on tick over and every now and again when driving.
Old Jun 29, 2011 | 08:16 PM
crossy2004's Avatar
crossy2004
80 not good rebuild time soz
Old Jun 30, 2011 | 07:27 AM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
Rebuild time for it i am sorry to say
Old Jun 30, 2011 | 05:38 PM
tay14's Avatar
tay14
your right mate but would low comp across all 4 cylinders cause the intermittent miss,or is that still a separate fault?as i would prefer to get the miss sorted then rebuild the engine.
Old Jun 30, 2011 | 06:15 PM
gazzas1982's Avatar
gazzas1982
i had a similar problem with mine it was the dizzy the plug on top of the dizzy has 3 wires going from that into the back of the dizzy and it got cought inside the dizzt and chopped 1 have a look u never know
Old Jun 30, 2011 | 06:51 PM
crossy2004's Avatar
crossy2004
id try yellow temp if i were u and do have a look at dizzy at back. ive noticed that if i pull on the wires and push in on the crossover it hisses at me does yours
Old Jul 6, 2011 | 05:45 PM
tay14's Avatar
tay14
Smile
the cars fixed!!!!!!!!!!
1st things 1st never borrow a dodgy looking pressure tester of your dad!!!
dropped the car of at aet turbos on monday to get checked over,told them the faults and the low pressure readings ect.got a call today to go pic the car up all sorted,they did a pressure test came back at around 140 each cylinder.and the missfire was down to the wires that run around the front panel to the coil braking down,fitted new wire car runs spot on.
Old Jul 6, 2011 | 05:55 PM
milesy23rst
PUG 306 GTI-6
Great news m8 glad my old car is all sorted lol
j.hammond1
30
Oct 31, 2021 05:28 PM
Brickhouse
Sep 21, 2015 11:00 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
taylora1409
Aug 12, 2015 12:06 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
