ST170 on ITB's, which cams?
I have gsxr 750 throttle bodies, and an Omex loom for the 170 . Omex ecu to buy when I grit my teeth hard enough and sink a few beers to take the pain away
Can anyone recommend decent cams for the job ?
Get some 13mm plus cams and piston cut outs done and you will see some good numbers
If you go with Cat Cams they do a cam to remove the VVT
A friend of mine has seen 270bhp on an ST170 engine but it had high comp, headwork and a huge cams on TB's nasp
Mc5506
Oct 5, 2015 09:57 PM
