brakeing s2 rs turbo in the next week or so
goin to be braking my rs turbo up in the next couple of weeks iv listed most things but just ask if there is anything you need that isnt listed.
Turbo very good condition with a 32 collins actuater £250
pro alloy rad £250
pro alloy fmic with spool fans £300
a brand new pattern bonnet £50
a rot free boot lid of an escort £50
metering unit £65
brand new clutch lightend flywheel and uprated pressure plate £130
set of 5 wheels with tyres good condition £90
brand new engine mount £25
powder coated engine mount black £40
efi rocker cover in wrinkle black £30
standard rocker cover clean on out very dirty on inside £25
oil cooler with some pipe work £30
oil catch tank £20
baileys dump valve with t piece £60
gear box £100
electric oil pressure gauge £25
starter motor £25
alternater *2 £20 each
amal valves *2 £20 each
chipped ecu £70
powere flow stainless exhaust with 2half out let not very noissy open to offers
also have a freshly rebuilt engine done less than 50miles with recipts for £1300 with out half the parts.
crank reground .25
mahly low comp pistons
kent 35 cam
kent adjustable pully
fast road valve springs
uprated valves
ported and pollished head
new water pump
new alternater
new timeing belt kit
every gasket new and stem seals
all sprayed and looking good built by a&r engine builders
open to offers ???
the shell must go to very solid had a new cross member and hole front pannel all rot cut out of battary tray new tray put in open to offers its black and comes with mot on it
i have a spare engine to that is prob good for parts with a newman cam in it open to offers
i have every thing here all water pipes boost pipes standard fans intercooler rad seats another 5 alloys loads of bits if you need any thing let me no all price are excluding p+p
pro alloy rad £250
metering unit £65
oil catch tank £20
gear box £100
starter motor £25
chipped ecu £70
crank reground .25
kent 35 cam
uprated valves
new water pump
new alternater
open to offers ???
What interior is it 88 or 90 spec and what are the front and rear seats like and door cards???? what brakes has it got??? and may also be interested in a set of standard wheels and can pick up as am only in torquay mate
the car is 89 im not sure on the spec front and rear seats are in good condition door cards are abit worn on handles you can come and have a look if ya want mate
Matt Baxter
Sep 16, 2015 08:30 PM
track.focus'd
Aug 12, 2015 05:53 PM
Red_bull
Aug 9, 2015 08:34 AM
