Amal valve on Ofab??
Old Jun 3, 2011 | 10:38 PM
rsbondy's Avatar
rsbondy
Default Amal valve on Ofab??
Awritey, I was tinkerin in garage tonight and I'm in middle of convertin my Rs turbo van to Ofab from mfi Noticed there's no plug on Ofab engine loom for the Amal valve,... Do I need an Amal valve on Ofab and if not where do the small hoses from turbo and actuator go to??
CheeRS bondy
Old Jun 3, 2011 | 10:49 PM
rst cabbie's Avatar
rst cabbie
gingeRS cabriolet
haven't got one on mine
Old Jun 3, 2011 | 10:56 PM
rsbondy's Avatar
rsbondy
Where do the small hoses go to from the turbo and actuator now if not to the Amal valve mate??
Old Jun 3, 2011 | 11:02 PM
rapidonion's Avatar
rapidonion
either loop the hose from the comp housing to the actuator, or fit a bleed valve (not my cup of tea) or fit some sort of electrical boost controller (i use a hks one)
failling that you could use your amal valve to give you 2 stage boost + to live and - to a switch and then ground.
Old Jun 3, 2011 | 11:16 PM
rsbondy's Avatar
rsbondy
Am not a big fan of bleed valves either to be honest, so loopin the hose from compressor housing to actuator wil be fine yeah?
Old Jun 3, 2011 | 11:55 PM
rapidonion's Avatar
rapidonion
bit fiddly to set up the actuator but once sorted youll be fine.
cheers mike
Old Jun 4, 2011 | 06:36 AM
rsbondy's Avatar
rsbondy
Any other input on this??
Old Jun 5, 2011 | 10:58 AM
rsbondy's Avatar
rsbondy
Any1??
Old Jun 5, 2011 | 11:28 AM
luke19790_3's Avatar
luke19790_3
Have a ofab amal valve for sale
steve.rst
Mar 15, 2016 08:01 AM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
rs_jim
Sep 19, 2015 08:41 PM
