Ford sierra 1.6 cvh improvement
hello again!
i hove one more question about the lazy 1.6 80hp sierra
is there any way to make this engine produce more hp by reprogramming the ecu?
i know that this engine is made for not to take any modifications but i don;t want to accept it
i can believe that it produces only 80 hp while other engines of the same age were producing at lest 100hp
can i do somethinh except from changing parts from the inside of the engine?
You can improve it, without going inside the engine, but it will be a serious money pit, for next to no gain, this would involve different ecu/injection/exhaust etc.
A serious waste of time trying imo.
can anyone tell me the difference between cosworth springs and thsese from 1.6cvh..
i ask it beacause i putted eibach springs code 3503-240(which propable are for cosworth) to my cvh and the look is terrible..the car seems to be loaded at the back....
i have this fear so i would like to know!!!thanks
What he said ^^, the Cosworth is lower than lesser models, and as such the springs are shorter are rated differently.
In addition, the whole rear beam is different on a Cosworth model (2WD), as are the trailing arms, the latter are different so as to suit the lower ride height IIRC.
To be honest you most likely have ruined the geometry and it will handle worse on those than it did before!
Martin
Martin
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
