Identifying my gearbox - help please !!
Old May 30, 2011 | 07:03 PM
s2turbsZVH's Avatar
s2turbsZVH
Will it ever end !!!!!!!
Default Identifying my gearbox - help please !!
I have just taken the gearbox off my RS to change the release bearing but now I am starting to think its an IB5 Gearbox from a Mk5 Escort diesel.
The part number on the casing is 96WT - 7F096 - EA IV/1
Can anyone help in trying to identify it please as i just want to make sure i get the right bearing.
Also how different is an IB5 to the standard BC box - i.e gaskets etc etc
Pic attched
Old May 30, 2011 | 07:04 PM
luke19790_3's Avatar
luke19790_3
yep ib5
Old May 30, 2011 | 07:06 PM
Rst tyrone's Avatar
Rst tyrone
zetec turbo
defo ib5 same box im running mate
Old May 30, 2011 | 07:07 PM
luke19790_3
its got the ribs and 4 mounting bolts.
was told the Release bearing part no is EQ5918
http://www.clutch-specialists.co.uk/...part_no=EQ5918
Old May 30, 2011 | 08:08 PM
s2turbsZVH's Avatar
s2turbsZVH
Thanks for the info - confirmed my suspicions - just nice to get clarification.
Old May 30, 2011 | 09:01 PM
juffer's Avatar
juffer
Im in 2 minds on buying a refurb one. What are the gear ratios like?
Old May 30, 2011 | 09:04 PM
luke19790_3
just got one of ebay i will see
Old May 30, 2011 | 11:52 PM
MO' BENT RIMS's Avatar
MO' BENT RIMS
1st gear is shit after that its perfect
Old May 31, 2011 | 07:17 AM
luke19790_3
Don't you have quaife gear set?
Old Jun 5, 2011 | 08:40 PM
juffer's Avatar
juffer
s2turbsZVH - What bearing did you fit in the end and have you got a part number?
Old Jun 6, 2011 | 02:09 PM
s2turbsZVH's Avatar
s2turbsZVH
Hi - got in touch with a guy at Ford as I was advised to fit a ford item as the pattern ones are not up to much - the FINIS code is 7166796.
Problem is though is that it works out at Ł50.33 !!
I figured that better to pay the extra for the quality as opposed to putting a cheap pattern on only to have to change again soo.
Old Jun 6, 2011 | 02:25 PM
Ben26's Avatar
Ben26
what do u mean its shit ?
how ?
Ben
Old Jun 6, 2011 | 09:22 PM
juffer's Avatar
juffer
JESUS !!! Thanks for the part number.
Ben- i think he means its very short.
Old Jun 6, 2011 | 09:36 PM
Ben26's Avatar
Ben26
yea my 1st gear is very very short, turbo does not even spoil up, its got 1986 stamped on it as well, so it mite of come off a 1.1 which could have a closer ratio maybe, and its doing 7000k in 5th and will only do 130mph
Old Jul 23, 2011 | 07:50 PM
dudesfezaddicition's Avatar
dudesfezaddicition
hi guys, hope one of you can help. just had a punt on a" recon. rs turbo box" off ebay. has new seals/bearings and looks like has been worked on(also has blue bolts?) but to be honest not sure if has l.s.d. or what i'm looking for! has part numder 87TT-7F096-BB I/2 on casing. anybody know ?
Old Jul 24, 2011 | 09:42 AM
luke19790_3
have a look where the drive shafts slot in, if you see a bar going across then no lsd
Old Jul 27, 2011 | 02:43 PM
dudesfezaddicition
nice one luke , no bar, looks like a good one. just need to find a day ,( or i am being hopeful?) to swap. thanks for help m8
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
gingeRS
Sep 4, 2015 06:29 PM
