cvh block breather baffle
Is it recommended to install and use the factory breather baffle in the bottom end?
Here is a picture of the device:
I am thinking I would like to delete this spring loaded baffle.
Opinions?
I would hate to have it fall out and get hit by a whirling crankshaft.
Opinions?
Thanks guys!
I was just looking for cvh expert opinions.
I will leave it alone then.
The stud kit is overkill I guess. But I have always used stud kits in all my performance engines. I don't really see the point in re-using 25 year old fasteners.
The studs do a better job of holding the bottom end together.
Factory bolts are certainly capable - I just like the added safety margin for the 88mm long stroke crank at 7000 rpm.
mk3ste
Oct 17, 2021 10:09 AM
