Left engine mount 4x4
Old May 21, 2011 | 06:42 PM
captiva's Avatar
captiva
Default Left engine mount 4x4
Do you have to remove LH drive shaft to change LH engine mount. I've let go both engine mounts and crossmeber and still not enough room
Old May 21, 2011 | 06:53 PM
RS500/364's Avatar
RS500/364
Sure easy to support the engine and drop the cross member
Old May 21, 2011 | 07:07 PM
Paul_RS's Avatar
Paul_RS
You don't have to drop the crossmember. Turbo heashield off, boost hoses off and inlet manifold off was plenty of room for me to be able to change mine. Just engine craned the engine for support. Unbolt the engine support arms to allow room to lift the old engine mounts out.
Old May 21, 2011 | 07:08 PM
captiva's Avatar
captiva
I've done that but as I try to lift engine and drop crossmember the crossmember touchs the driveshaft and stops you getting any more clearance
Old May 21, 2011 | 07:11 PM
captiva's Avatar
captiva
i HAD THOUGHT OF THAT BUT THE OIL FILTER EXTENSION STOPS YOU GETTING TO THE 4 BOLTS ARM TO BLOCK
Old May 21, 2011 | 07:19 PM
Paul_RS's Avatar
Paul_RS
I must have moved that too - its only held on by the large nut into the block and on 17mm IIRC bolt into the engine support arm?
Old May 21, 2011 | 07:32 PM
captiva's Avatar
captiva
Don't know what to do now as I have all suspension hanging and just the driveshaft in the way or put it all back together and try it your way. It's the middle of the day here so I am fixing it as I type this, guess I was looking for an intant fix
Old May 21, 2011 | 07:34 PM
Rex Kramer's Avatar
Rex Kramer
Danger Seeker
When I done mine recentley I took the inlet plenum off and loosened the big bolt on the oil filter extension arm and the 17mm bolt, as mentioned above, to allow access to the bolts securing the arms.
Old May 21, 2011 | 07:37 PM
captiva's Avatar
captiva
Is there a rubber seal in behind the oil filter extension, one that I haven't got?
Old May 21, 2011 | 10:07 PM
Paul_RS's Avatar
Paul_RS
There's an o-ring in there, similar to the seal on your oil filter. Its easier to move that arm than fight the driveshaft in and out lol
Old May 21, 2011 | 11:33 PM
captiva's Avatar
captiva
Dun it now, had a fight with the drive shaft, ripped it out the car and slung it over the hedge! Poxy thing. Anyone got a good drive shaft???????????????????????????
Old May 24, 2011 | 03:26 AM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
All you needed to do was take the oil filter arm off to get to the engine mount legs that go into the block. Know it's too late to say lol, sorry. Plus you wouldn't have lost any oil as it would have been in the sump as it were. there ar
Old May 24, 2011 | 03:28 AM
kosienutter
There are four bolts that go into the block that hold the mount leg in.
Old May 24, 2011 | 03:47 AM
captiva's Avatar
captiva
Thanks anyway I'll know for next time. Hope there isn't a "next time"
Old May 24, 2011 | 08:20 AM
myaRSe's Avatar
myaRSe
I know it's too late but no need to remove anything jack up the engine cut the bolt on the old mount with a hacksaw to get it out and if fitting uprated ones the new centre bolt is removable, jobs done but not easy
Old May 24, 2011 | 08:26 AM
Graceland's Avatar
Graceland
Team HOTHOT!
A bit late now, but easy way to do the job is as follows.
1) Remove intercooler to inlet hose
2) Remove oil modine to inlet bracket (small bracket, not all are still fitted as it hardly ever gets put back on)
3) Slacken oil modine and lift up untill it touches inlet manifold and then retighten to hold there
4) Remove engine mounting top nut from arm to rubber mount
5) Support engine from under the sump with a jack and wooden block
6) Remove the 4 bolts that hold the alloy arm into the block and lift arm out of way
7) Remove 2 enging mounting bolts that hold mount to crossmember
8) Refit in reverse order
Time taken - 1 hour and that would include a brew half way through
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Caddyshack
Aug 19, 2015 07:29 PM
track.focus'd
Aug 12, 2015 05:53 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
Old ford
Jul 31, 2015 06:50 AM
