Cosworth loom help please.
Old May 20, 2011 | 08:03 AM
retro d's Avatar
retro d
Default Cosworth loom help please.
Okay so I've fitted my loom to my engine, the live feed and coil wires are on and all other plugs/ earth.
The main live feed,ignition and fuel pump are all on inside, and I have set the crank sensor gap and checked all leads are in the right order.
It cranks over but wont fire I have a spark at the coil and all four leads, just not sure what's wrong .
Also I have checked the feeds with a test light at the dizzy and crank sensor and they don't seem to have a live feed.? however the ignition module does, and so has the tps sensor but it is a very dim feed.?
Any help would be great thanks..
Old May 20, 2011 | 08:32 AM
RS500/364's Avatar
RS500/364
New loom old loom 09 tps or
Old May 20, 2011 | 10:13 AM
retro d's Avatar
retro d
Its the loom with the two black live feeds instead of red/blue wire
big_Rad
Sep 15, 2017 09:36 AM
muz
Aug 16, 2015 12:57 PM
Aug 14, 2015 07:29 AM
gingerturbo
Aug 11, 2015 09:44 PM
jdsjojo
Aug 1, 2015 08:50 PM
