Extreme price difference?!
Old May 19, 2011 | 08:57 AM
Chopshop85's Avatar
Chopshop85
Default Extreme price difference?!
Looking for some bits for my cvh for when I get the pistons skimmed.
Is there any particular reason why a full 11 piece engine gasket set from my local motor factors is £40 and 1 cometic head gasket is £116?!?!
Old May 19, 2011 | 09:14 AM
RSNUT!'s Avatar
RSNUT!
i dont think you get a head gasket in the kit mate i would check...
Old May 19, 2011 | 09:20 AM
Joshy's Avatar
Joshy
Dreamer
agreed, head gaskets are normally £20 alone IME
Old May 19, 2011 | 09:24 AM
Chopshop85's Avatar
Chopshop85
"includes head gasket" apparently.
Old May 19, 2011 | 09:27 AM
Chopshop85's Avatar
Chopshop85
Even cheaper :s?!?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...T#ht_800wt_905
That kit even includes stem seals!
Old May 19, 2011 | 09:53 AM
Chopshop85's Avatar
Chopshop85
Found out the difference. Going to go with a "genuine ford" head gasket.
Old May 19, 2011 | 11:29 AM
RSandy's Avatar
RSandy
genuine ford/payen is definitely the way to go, at least with the headgasket, sump gasket, and exhaust manifold gasket anyways
Old May 19, 2011 | 11:46 AM
dangerousbrian's Avatar
dangerousbrian
i bought a full cvh head set and that came with h/g and valve stem oil seals as well..the only thing that wasnt there was the gasket for between the two part inlet manifold on a s1
Old May 19, 2011 | 05:10 PM
Karlos G's Avatar
Karlos G
Balls Deep!
What pistons are you having skimmed and why mate?
I buy my gasket sets from http://cgi.ebay.co.uk/FORD-ESCORT-RS...item518a3b3d19 comes with a Payen HG.
Old May 19, 2011 | 05:17 PM
Ben26's Avatar
Ben26
yea gaskets for classics on ebay are spot on .
I ordered 4 full sets inc head gasket , the head gasket is exactly the same as O.E ford but at a fraction of the price . it has th efire rings where alot dont, you can not go wrong with O.E head gaskets for the CVH, all the big power cars have them and heard alot of the MLS gaskets can fail if the head/bloack is not 100% true
I also bought some payen head bolts off him dirt cheap , but they will be the same as ford
Very good company IMO
Ben
Old May 19, 2011 | 07:26 PM
Chopshop85's Avatar
Chopshop85
Whatever pistons are in there! lol. Need to lower the comp ratio a bit.
Old May 19, 2011 | 08:13 PM
Rob_DOHC's Avatar
Rob_DOHC
Why do you need to lower the compression ratio? I wouldn't on the next engine i build.
There are people with over 300brake and a standard ish compression ratio.
PS, my pistons were skimmed, standard mahle. But as above, i wouldn't again. But i would definitely use ford gaskets ALL the way through.
Rob,
Old May 20, 2011 | 12:22 PM
Chopshop85's Avatar
Chopshop85
Rob,
My tuner reckons the comp ratio is too high. It was something like anything over 12degree's ignition and 13psi of boost it would det regardless of what he did. As far as I know the head has been skimmed twice which he said could affect it.
Old May 20, 2011 | 02:11 PM
Rob_DOHC's Avatar
Rob_DOHC
Who's your tuner mate?
For instance Karlos G above is running standard compression plus some more as his block and head were skimmed, and i was running 17psi with standard compression before the rebuild.
Rob,
Old May 20, 2011 | 04:10 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah I run 27psi peek at above stock CR so either you've got NA pistons (which are fit for the bin) or something else is wrong with your setup?! lol
Chopshop85's Avatar
Chopshop85
Rob,
Cooper from Northampton Motorsport.
The weird thing is it was running about 17psi making around 165bhp. Then I had to wind it down a bit as the clutch was no good. Got an uprated clutch fitted and now the car just won't get anywhere near the figure it did before. Nothing else has been changed.
Old May 20, 2011 | 04:21 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Is it going lean, what are your AFR's? Are you MFI still?
Old May 20, 2011 | 04:26 PM
Chopshop85's Avatar
Chopshop85
I am MFI still. Not to sure on the specifics as this was the first time I had just dropped the car off rather than just stay with it.
Anything else that could cause it? I remember he said there is plenty of fuel pressure so I Guess it wouldn't be running lean.
Old May 20, 2011 | 04:57 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Det is normally caused by either not enough fuel and/or too much advance.
Perhaps the MAP sensor in the ECU is dead, quite common these days, not pulling the timing back as it should when boost increases, try another ECU before you go stripping the engine!! lol
You say anything over 12 degrees and it dets, is that static timing? If it is then it should be pulled back to around 8-10 degrees anyway, you cant run much boost at 12 degree's let alone more advanced than that.
Old May 20, 2011 | 05:13 PM
Chopshop85's Avatar
Chopshop85
Oh right. Might be worth looking at, Although its getting my hands on another ecu.
Sorry I meant to say 8degree's before tdc. Dont know where I got the number 12 from?! The engine is coming to bits to have a new cam fitted anyway. I think 120,000 miles on one cam (as far as I know its not been changed) is pushing it a bit.
Old May 20, 2011 | 05:16 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Fuck me!! If it's done that many miles I'm suprised your getting enough air in to Det at all, lobes must be nearly round?!!! lol
Old May 20, 2011 | 08:19 PM
Chopshop85's Avatar
Chopshop85
Yeah, its only just started to get a little bit noisy as well!
I'm gonna have a word with my tuner and see if we can give it a quick run with another ECU. I'm sure I have a friend that will let me borrow his. Just to eliminate that.
Old May 20, 2011 | 08:31 PM
dangerousbrian
what is the life expectancy of the cams? mines done 150k and im pretty certain its hasnt had a new one fitted.
Old May 20, 2011 | 08:41 PM
Chopshop85's Avatar
Chopshop85
Thinks its around 60-80 thousand miles IIRC.
Old May 20, 2011 | 10:40 PM
Rob_DOHC's Avatar
Rob_DOHC
Lol try sub 20,000 miles normally.
Rob,
Old May 22, 2011 | 11:05 AM
Rogeyboy's Avatar
Rogeyboy
Oil & filter change and cam every 6,000miles lol!
Chopshop i have a spare ECU, early 1 not a hearts & diamonds... PM me if you need 1!
Old May 22, 2011 | 11:16 PM
DanRSturbo's Avatar
DanRSturbo
Mine made 155 @ 10psi so 17 should have you in the 180 - 190 mark surely, what cooler you running ? Does it hold back when you floor it ? I've got no receipts for a cam and I'm on 142k and still going strong.
Old May 22, 2011 | 11:51 PM
Chopshop85's Avatar
Chopshop85
Just looked at my big wad of print outs. I got my numbers mixed up. (the amount of times this thing has been on the rollers! ) 17psi it was 181bhp. But the clutch was having none of it so we knocked it down to 165bhp. Which lasted a few week's until the clutch got on its last legs.
I have an airtec front mount.
jessie_rs
Jan 5, 2016 01:16 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Kam B
Sep 24, 2015 10:40 AM
jessie_rs
Sep 7, 2015 01:27 PM
