advice (picts inside) bottom end/head - also is the head ported?
Old May 14, 2011 | 06:15 PM
dave_s2_rst's Avatar
dave_s2_rst
Default advice (picts inside) bottom end/head - also is the head ported?
Evening all,
So the lovely day which all RS owners come to finally arrived. The head cam off due to the cam and a tappet being munched as suspected.
The head was removed(been on car for 3years) and noticed the pistons looking rather caked! along with the top end, is this from running rich?
Also I noticed the head had been welded as seen here:
So should I ditched the head, is this bodged? Also what are the standard inlet/exhaust port sizes?
Many thanks
Dave
Old May 14, 2011 | 06:17 PM
studabear's Avatar
studabear
Is that a zvh as my pistons didn't look like that, if it is that may be why the head has been welded
Old May 14, 2011 | 06:18 PM
dave_s2_rst
Yes it is a zvh,
Ah i see
Old May 14, 2011 | 06:21 PM
studabear's Avatar
studabear
I'm no expert but I'm sure I've read somewhere that when the heads been welded its to allow use of a differant headgasket, focus rs springs to mind
Old May 14, 2011 | 06:24 PM
dave_s2_rst
I'll have a look into that, cheers dude.
The one removed looked to be a triple layer type?
Old May 14, 2011 | 06:26 PM
studabear's Avatar
studabear
http://www.quantums.info/zvh.htm#Cylinder Head gasket
Old May 14, 2011 | 06:42 PM
dave_s2_rst
cheers mate
pinched this from the site
"The oil feed to the Zetec head goes closer to the edge of head than on the CVH and if you put a Zetec head gasket on a CVH head the oil just leaks out the gap. You can get the side of the CVH head built up with weld and then the head skimmed to enable you to use Zetec head gaskets."
Old May 14, 2011 | 07:07 PM
dave_s2_rst
Just another question, what are the normal exhaust port sizes in compared to a ported type.
Here is mine:
Old May 14, 2011 | 10:32 PM
Rob_DOHC's Avatar
Rob_DOHC
It looks like your exhaust ports have been opened up mate, they are no where near that size stock, and are flat bottomed. I've got an old thread some where showing some standard ports if you wanted a comparison.
Rob,
Old May 16, 2011 | 11:29 AM
muz's Avatar
muz
Wye Valley Hardcore
Not sure what the pistons are, is it a 1.8 or a 2.0? What does the bore measure?
The head has been welded up to use a Zetec headgasket. Much better.
The exhaust ports are very big. They look like 39mm. Mine have been worked and are 37mm
Old May 16, 2011 | 11:30 AM
muz's Avatar
muz
Wye Valley Hardcore
On a side note though, the valves themselves look standard, in size and material? What do they measure?
Old May 16, 2011 | 10:42 PM
dave_s2_rst
i'll have a check and update you guys, would be good to get info on what has been done previously.
Its a 2.0 zvh
Old May 17, 2011 | 09:17 AM
dave_s2_rst
inlet is 40mm
exhaust is 35mm
does that mean anything?
Old May 17, 2011 | 09:34 AM
muz's Avatar
muz
Wye Valley Hardcore
Valve sizes? Standard valves should be 42mm inlet 37mm exhaust. I think most heads can only accept a 43mm inlet 'oversize' valve without a crosshatch head but keep the same sized exhaust valves.
Old May 17, 2011 | 09:41 AM
dave_s2_rst
i'll having a measure with my rule once out, sounds like they are more or less standard sized.
Old May 17, 2011 | 10:13 AM
dave_s2_rst
Bailes1992
Sep 3, 2015 02:17 PM
kevin36
Sep 2, 2015 06:24 PM
IAN RS2k
Aug 18, 2015 07:51 PM
ekjim
Aug 17, 2015 08:57 PM
john_3.0s
Aug 15, 2015 07:44 AM
