Pink to Radiant Red - how? bufties please help!
Old May 8, 2011 | 04:34 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
Default Pink to Radiant Red - how? bufties please help!
hey all,
Just starting my saffy project car, the bodywork itself is clean, but unfortunately it's faded! has anyone got any tips to make it shine again and prolong its redness? without spending a fortune?
any help would be much appreciated!
Old May 8, 2011 | 06:10 PM
It's Czech Mate's Avatar
It's Czech Mate
Get it mopped then use a good sealer and polish
Old May 8, 2011 | 06:30 PM
matts1's Avatar
matts1
years back I had a red xr3i that was faded to pink and in places white!! I spent about 5 hours t-cutting then polishing and it came up like new.
Maybe give it a really good wash down, clay bar it to remove any crap in the paint (very quick and easy to do) and then give it a good t-cut and then polish up then wax.
If it is kept waxed up reguarly then the red should remain.
Old May 8, 2011 | 06:38 PM
howie1989's Avatar
howie1989
a mop should work if u use a cutting compound then polish i did my capri bonnet that was like a matt pink and that has come up really well
Old May 8, 2011 | 07:03 PM
chunk123's Avatar
chunk123
hey im a bit of a detailer , if your not machine polishing the cheapest way way would be to T-cut but this wont give a good shine so following up with a good polish will help, autoglym super resin polish is great for this ! and to keep its colour a good wax will or sealent is the way forward, im using autoglym HD wax at the moment and its awesome!
Old May 8, 2011 | 07:10 PM
JonnyBravo's Avatar
JonnyBravo
Alright mate, I've just done my mates Audi for him, looked like a right nail when we picked it up.
Old May 8, 2011 | 07:14 PM
gus's Avatar
gus
boy done well
Old May 8, 2011 | 07:29 PM
Mark_'s Avatar
Mark_
give us a quick run through of what you used please, thats an amazing result to say the least
Old May 8, 2011 | 07:39 PM
JonnyBravo's Avatar
JonnyBravo
The car was washed down with a mix of traffic film remover and water, then it was all washed off with a pressure washer.
We taped up the windows and plastics and I used a simple foam mop head and G3 using plenty of water to avoid burning through ( mainly as my mop has no speed control )
I then mopped it with a normalish car polish I have from Nielsons, I've always found this helps get any of the swirls you may find from machine polishing ( again possibly more down to the mop I use )
The car was then washed down a final time and the we hand polished it with Auto Glym Super Resin.
Simple as that really, very impressed with the results.
Old May 8, 2011 | 07:43 PM
Mark_'s Avatar
Mark_
nice one, you make it sound so easy., lol
Tfr is great stuff isnt it. we got 100s of litres of the stuff at work.
although ive seen what it does to red cars if its not mixed correctly.
it makes red cars pink.
Old May 8, 2011 | 07:47 PM
JonnyBravo's Avatar
JonnyBravo
From experience I have found that using TFR on similar coloured vehicles helps bring it up once you hit it with polish.
I always mix it but nothing like as much as I would now its been polished.
I had been a valeter for about 6 years, I had my own place for 3 years doing it but stopped not long before the foreigners took over all the garages in my area. Not a bad job to have and great when you get results like that.
Oh and thanks
Old May 8, 2011 | 10:14 PM
Turbo Zetec
Engine Machinist
Oh and thanks
Well Jon, if you get bored you can always come and do it for me!
its my new project car, so want to get it shiny before i put the new bumpers on
Old May 9, 2011 | 11:34 AM
oibren85's Avatar
oibren85
If in Doubt Flat Out...
Jonny, When you say you use plenty of water, is is sort of spray it on while your machining? how does it react with the polish when applying?
Old May 9, 2011 | 02:12 PM
st170dan's Avatar
st170dan
if you can machine polish then do that as it will be far quicker and easier. if not, as suggested use t cut, ive had good results with that on a red bonnet.
Old May 9, 2011 | 04:03 PM
Mark_'s Avatar
Mark_
when i see a mate mop his motor with G3 at work he soaked the mop head before using it and wet the panel then applied G3 straight onto the panel.
not sure if thats the correct way to use it but its what my mate did
Old May 9, 2011 | 04:11 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
As above, keep the mop damp but not wet, if it's too wet then be prepared to cover everything with watered down polish! Makes a right mess!
Old May 9, 2011 | 04:39 PM
bluntys1rsturbo's Avatar
bluntys1rsturbo
Boost addict
good old elbow grease will see you through
clay bar,ag hd paint cleanser, ag super resin polish, ag ultra deep shine and ag hd wax
this should do the trick or for a quicker method try turtlewax colour magic it did wonders for my other halfs worn out saxo followed up with a quick coat of ag ultra deep shine
Old May 9, 2011 | 04:54 PM
JonnyBravo's Avatar
JonnyBravo
You can borrow my mop anytime mate
That is how I do it, damp mop head and keep the panel slightly wet, especially on a car as faded as this.
You can use it dry or atleast drier but there is a high chance you will burn through on the edges and obviously you don't want to be doing that so I'd rather have a bit of G3 to clear up than something I can't without repainting the panel
The Audi needed the bumpers and other hard to get to parts removing as its not perfect, maybe I'm a bit anal but seeing how well it did come up I'm keen to get it looking as good as it can.
Old May 10, 2011 | 02:31 PM
oibren85's Avatar
oibren85
Cheers Jonny, sounds like i'll be doing some practice. Top Work...
Old May 10, 2011 | 02:37 PM
JonnyBravo's Avatar
JonnyBravo
I'm only 2 villages away from you, if you need to borrow anything or want some help drop me a PM
Old May 10, 2011 | 03:09 PM
**caz**'s Avatar
**caz**
when i first got my car it was rather pink, and then i asked one of the guys at work to give it a quick wash for me one day and he covered it in TFR and as said above...this stripped it completely and it was pink all over!!!!
I spent some time on it and got it nice and shiny again!
I use Megs Gold Class Wash, Dry, AG Super Resin Polish, Megs Carnuba Wax, finished off with AG Extra Gloss Protection! When Ive done it I constantly get comments on how red it is, and how shiny and reflective!
Old May 10, 2011 | 05:28 PM
oibren85's Avatar
oibren85
Cheers fella, might take you up on the advice some time.
Old May 11, 2011 | 12:40 AM
Byrnes1's Avatar
Byrnes1
2.0 MK6 Escort track slag
Bring it to me mart, I'm soon to be working for a detailing place right by Cambridge train station, failing that I might be able to borrow one of the rotarys one weekend and pop up to you and de oxidise th paint for you, unfortunately I sold my old makita rotary, pads, compounds last year. So I'll have to see what I can manage from the place in cambs.
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
