fuel tank removal
Old May 7, 2011 | 08:20 PM
lime's Avatar
lime
Default fuel tank removal
i have a fuel pump to change on a focus was wondering what is the best procesure to remove the tank because the pump needs to be replaced and if by any chance would any body have the part numbers for the pump
Old May 7, 2011 | 11:58 PM
pdfbt40's Avatar
pdfbt40
Why wasn't the Focus designed with an access under the rear seat..............
Try to do it when the level is low !
Undo the filler and vent pipe, disconnect and remove charcoal canister at rear. Disconnect filter (good idea to replace it while tank is dropped). Support tank, undo strap bolt. Lower tank, disconnect pipes and wiring. Undo access retainer and remove top cover. Turn fuel module to release from bottom of tank.
Might have changed, but Ford use to only supply a complete 'fuel module' though its easy to dismantle. Good after market suppliers (FSE in UK) can supply a bare replacement pump. Any where else, check against original pump as there are subtle differences, for example, in outlet pipe position.
Martin
steerfromdarear
28
Jan 29, 2016 06:14 PM
FlashRS
Sep 14, 2015 12:36 PM
mint_s2
Sep 2, 2015 08:58 AM
ekjim
Aug 17, 2015 08:57 PM
taylora1409
Aug 12, 2015 12:06 PM
