oil pressure gauge
Old May 3, 2011 | 10:48 PM
bubs_rsturbo's Avatar
bubs_rsturbo
Default oil pressure gauge
whats involved in fitting one? i assume they are a very good idea
cheers Neil
Old May 3, 2011 | 11:00 PM
beaver rs 88's Avatar
beaver rs 88
in the garage
tee piece on back of block for sender few wires and bobs your uncle, easy to fit and yes there very good foe keeping an eye on your engine. nothing to loose by fitting 1 so get it done mate
Old May 4, 2011 | 08:31 AM
russ rs's Avatar
russ rs
Mechanical
Old May 4, 2011 | 09:10 AM
Rob_DOHC's Avatar
Rob_DOHC
Either way, mechanical or sender they are easy to fit, and a top idea. Especially for a new engine.
Rob,
Old May 4, 2011 | 07:28 PM
bubs_rsturbo
nice one guys im thinking of puting three gauges in, oil pressure, boost, whats the best to have as a third? cheers
Old May 4, 2011 | 07:30 PM
bubs_rsturbo
also are oil pressure gauges universal? or is there one for the rsturbo? cheers
Old May 4, 2011 | 08:00 PM
rst230bhp's Avatar
rst230bhp
I got oil temperature, need a volt meter next
Old May 4, 2011 | 09:48 PM
dave_s2_rst's Avatar
dave_s2_rst
defo oil temp in there
Old May 4, 2011 | 09:51 PM
bubs_rsturbo
that looks the part mate cheers
Old May 4, 2011 | 09:53 PM
Rob_DOHC's Avatar
Rob_DOHC
I've got the same stack as above minus the oil temp. Think i will get an exhaust temp if i get another when im running more boost any how.
Rob,
Old May 5, 2011 | 10:03 AM
Rogeyboy's Avatar
Rogeyboy
Gotta have oil temp so you know wen its warm enough to give it some shit...
Dave s2 rst - what gauge pods are they?
Old May 5, 2011 | 11:37 AM
russ rs's Avatar
russ rs
Do you run it off feed for turbo??
Old May 5, 2011 | 11:39 AM
Rob_DOHC's Avatar
Rob_DOHC
Maybe, or just wait until the coolants warm + a few miles, this holds true in the birds MGF which has an oil temp gauge. Im going to have oil temp on a digital display where the trip comp goes. But i don't think its essential so to speak.
Rob,
Old May 5, 2011 | 11:52 AM
pani_k's Avatar
pani_k
PassionFORD Member
Water temp+ another 10-15mins is fine for warm weather but you'd be surprised how much longer it takes to get up to proper oil temp in the winter.
Old May 5, 2011 | 12:41 PM
Rob_DOHC's Avatar
Rob_DOHC
I dont drive mine in the winter
I will get one eventually, but when im running more boost an exhaust temp gauge will do me more favours.
Rob,
Old May 5, 2011 | 12:47 PM
bubs_rsturbo
rob are oil pressure gauges universal or do i need on to suit the rs turbo? cheers
Old May 5, 2011 | 12:54 PM
dazrsturbo's Avatar
dazrsturbo
gauges are universal mate
Old May 5, 2011 | 12:59 PM
bubs_rsturbo
excellent mate thank you
Old May 5, 2011 | 01:17 PM
Rob_DOHC's Avatar
Rob_DOHC
As said mate, any oil pressure gauge will work with any car. Give reyland a call for stack gauges if they are what you want, they gave me the best price.
You will need a t-piece adapter, i have never bought one as my car came with one, but im sure lots of firms will supply one. The gauge t's off of the oil pressure switch (and turbo feed) at the back of the block.
Rob,
Old May 5, 2011 | 02:23 PM
bubs_rsturbo
Rob,
what about the smith ones you had for sale? still available?
Old May 5, 2011 | 02:31 PM
Rob_DOHC's Avatar
Rob_DOHC
They are mate, think i have volt/oil temp and oil pressure.
Rob,
Old May 5, 2011 | 02:35 PM
bubs_rsturbo
Rob,
im interested in your oil temp and oil pressure please mate £30 posted to belfast?
Old May 5, 2011 | 03:38 PM
Rob_DOHC's Avatar
Rob_DOHC
Let me dig them out at home mate and take a look. The oil pressure works fine, but i think the oil temp gauge needs a new sender.
Rob,
Old May 5, 2011 | 05:50 PM
bubs_rsturbo
Rob,
ok mate sounds good cheers
Old May 5, 2011 | 06:09 PM
martysmartie's Avatar
martysmartie
Gauges are unified generally but the sender MUST be the correct one for the gauge as they are calibrated!
Martin
Old May 5, 2011 | 06:15 PM
bubs_rsturbo
Martin
thanks for that martin
Old May 5, 2011 | 09:24 PM
Rob_DOHC's Avatar
Rob_DOHC
Martin
All my stack gauges self calibrate on every ignition on, and the smiths gauges have a calibration screw on the back. Not rocket science.
Old May 5, 2011 | 11:00 PM
dave_s2_rst
Alright dude,
The pod is a cheapo jobbie off ebay, but does the job and only about a tenner!
Old May 6, 2011 | 06:21 PM
bubs_rsturbo
still interested in these mate
IainRS1700T
Sep 25, 2015 06:44 AM
dombanks
Sep 21, 2015 08:38 PM
Brickhouse
Sep 21, 2015 11:00 AM
coscor86
Sep 20, 2015 01:21 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
