What next? GT30??
Old May 3, 2011 | 08:53 PM
Danny.'s Avatar
Danny.
Default What next? GT30??
Always looking to squeeze more out more power.
Where would you go with my current spec? i.e turbo and management??
T34.63
Greys on a L6
Set up at M.A.D
Engine Spec-
205 block 1.0mm oversize
1.0mm oversize mahle forged pistons with cut outs
Standard comp (minus cutouts)
Ported & polished head (24mm exh, 26mm inlet)
BD14 inlet
Piper double valve springs and vernier pulleys
4x4 inlet & 14mm spacer
Cometic Multi layer head gasket
ARP stud and nuts
044 pump
Grp A coil pack
500 cooler etc
Thoughts?
Old May 3, 2011 | 09:00 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
TT T38, you know it goes well
Steve
Old May 3, 2011 | 09:10 PM
J1mbo's Avatar
J1mbo
B1mbo
1mm over size on a 205 block is more what I'd worry about when looking for more power, we know how temprimental they can be!
Old May 3, 2011 | 09:14 PM
Staffi's Avatar
Staffi
I'd personally stick with that Spec if it were me..
Old May 3, 2011 | 09:19 PM
Danny.'s Avatar
Danny.
Do you reckon I should leave it then? Would 1mm really make it a lot more temperamental?
Steve
I need to beat you this time!
Old May 3, 2011 | 09:20 PM
Danny.'s Avatar
Danny.
It gets boring though doesn't it!
Old May 3, 2011 | 09:21 PM
J1mbo's Avatar
J1mbo
B1mbo
I have seen 205 blocks on half mm crack with greens conversions and other on here have got away with 440/450bhp conversion
Its luck of the draw!
Old May 3, 2011 | 09:22 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
LOL
MOT friday so it might not be on the road anymore
Steve
Old May 3, 2011 | 09:23 PM
jamie956's Avatar
jamie956
How far can you go on a 205 block oversized to 0.5mm or 1mm.
Old May 3, 2011 | 09:39 PM
Staffi's Avatar
Staffi
Danny, did Mark put it on the rollers for you??
Just curious of what power you're making..
Old May 3, 2011 | 09:44 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Not that much the way i drove away from him lol
Steve
Old May 3, 2011 | 09:45 PM
Danny.'s Avatar
Danny.
Made 385hp/350lbft mate.
Old May 3, 2011 | 09:47 PM
Danny.'s Avatar
Danny.
Steve
I told you before I stayed back because of the black smoke screen!
Old May 3, 2011 | 09:48 PM
Staffi's Avatar
Staffi
Oh you've had that too Danny??
When we left Ford Fair last year it reminded me of a DIESEL......
Old May 4, 2011 | 03:53 PM
rsmark86's Avatar
rsmark86
my gt35 spins up no problems and the car picks up better than any t34 car so a gt30 can only be better so with standard compression like mine a gt30 would be the best mod you can do.....
dont even bother with a t38 as theres not alot in the price difference.
Old May 4, 2011 | 04:00 PM
JamesH's Avatar
JamesH
Don't bother with a T38, go straight to GT30. As said though, maybe pushing things if you did, given the +1mm on a 205 block
Old May 4, 2011 | 04:18 PM
gibbo frst's Avatar
gibbo frst
i have to say i had a tt t38 on mine and was awsome.. i thought next step gt3076 and to be honest wish i had kept the t38.. for the extra little performance even though its been mapped properly this time where as before just a chip my money would have been better spent elsewhere on mods.. but guess if i was going from t34 id go gt30 too..
although ill see if a std exhaust cam and remap on autronics makes it a bit nicer soon..
Old May 4, 2011 | 05:22 PM
KSA-Cossie's Avatar
KSA-Cossie
Nowt wrong with a T38 , unless you're a sheep.
Old May 4, 2011 | 05:52 PM
charlie luciano's Avatar
charlie luciano
GT30/71 gets my vote every time, coupled with some decent mods some have made 500 horsies
Luciano
Old May 4, 2011 | 06:05 PM
J1mbo's Avatar
J1mbo
B1mbo
Your gt35 comes on boost as good as a t34? You must have been in an appalling t34 engine
Old May 4, 2011 | 07:24 PM
rsmark86's Avatar
rsmark86
i was in dannys black escos when i had it and it was nms mapped and it was quick.... had low compression and my car goes better than that with a t34.63
but my cossie has
gt35/ external waste gate screamer ect reyland manifold
autronic sm4
long studded 200 block
forged pistons ( pocketed standard compression)
custom spec cams and head work done by grace engines
83lbs
swedish inlet
and so on
and it just picks up and goes with no problems, it makes full boost around 3700ish rpm and holds to 7500rpm 2.2bar
Old May 4, 2011 | 07:36 PM
J1mbo's Avatar
J1mbo
B1mbo
Fair enough, I do know that a gt35 engine wouldn't be anywhere near one of our t34 engines for response that must have been horrid to drive!
Old May 5, 2011 | 08:28 PM
rsmark86's Avatar
rsmark86
dont get me wrong it was a nice car but i love the kick that my car has, and when i was going to see it and was told it had a gt35 i thought its going to be a lag monster but its extremely driverable and realy responsive.
after buying it i broke the restrictor that goes to the external waste gate and the top boost pipe on the turbo side was badly split and on the rollers with both them problems it made 414bhp and 416lbs @ 1.5bar and its mapped for 2.2bar and that was with a standard 4x4 plenum and its now got a r&b swedish fitted, and its unreal with out the swedish at 2.2bar
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
Oct 9, 2015 07:38 PM
Rsmat
63
Sep 25, 2015 12:11 PM
Dicko&Vacant
Aug 23, 2015 03:11 PM
Aug 14, 2015 07:29 AM
