rs turbo lambda sencer
Old Apr 29, 2011 | 10:08 AM
steven8230_00's Avatar
steven8230_00
Default rs turbo lambda sencer
hi all ive started my 2.1 zvh to day for the first time and its runing rough back fireing and wont idle ether. Ive noticed on the down pipe there has been a lambda sencer welded in place an was wondering if it should be connected or if its been on a zetec at some point. Ive done a compretion test as follows no1 120lbs/in no3 130/lbs/in no4 125lbs/in no2 130lbs/in
and ive got fuel to all 4 injectors i dont seem to have any air leaks help apriceated thanks in advance
Old Apr 29, 2011 | 10:45 AM
luke19790_3's Avatar
luke19790_3
Which management you using
Old Apr 29, 2011 | 12:16 PM
steven8230_00
its on a standard ecu but chiped well according to fle bay and its a mfi
Old Apr 29, 2011 | 12:39 PM
SteveB's Avatar
SteveB
The boss will be there for connecting a wide band lambda to for checking fueling whilst tuning I'd expect...
Old Apr 29, 2011 | 12:59 PM
steven8230_00
ive been on the phone to sitec racing and they have told me i need after market management and fueling to get it spot on
Old Apr 29, 2011 | 02:02 PM
luke19790_3
Need to change it for the efi setup so you can adjust the fuel etc. You can you the fiesta rs turbo inlet and then megasquirt or pay someone to do it
Old Apr 29, 2011 | 03:48 PM
steven8230_00
would i need a efi loom as well whats involved mate
Old Apr 29, 2011 | 03:53 PM
luke19790_3
No just need the engine loom for the inlet/injectors. Do a search for karlos thread, covers the basics
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
