what should co be on a s2
Old Apr 26, 2011 | 07:55 PM
escort_matt's Avatar
escort_matt
Default what should co be on a s2
hello what co should it be on a s2?efi converted?is it 3.5%??
as mines on 11% on tick over
Old Apr 26, 2011 | 08:56 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
How was it converted?
What loom and ecu? Who did the work etc.
Typical
Old Apr 26, 2011 | 09:04 PM
stevealien's Avatar
stevealien
10 Year Member
my guy set mine up to 4.5 as he reckons they should run a bit rich.
but for mot i believe they have to be about 3.5,so i motd it ,then had it turned up a bit
Old Apr 27, 2011 | 11:37 AM
Rogeyboy's Avatar
Rogeyboy
Once mine was converted, it was 0.3% at idle - very lean!!!
Get it setup as it running very rich at idle
Old Apr 27, 2011 | 12:00 PM
Jimmyc's Avatar
Jimmyc
Mines a touch under 3.5% at idle, heard 3% was about right though?
Old Apr 27, 2011 | 12:39 PM
phil_rs's Avatar
phil_rs
yam yammer
Sounds like it's been to Jamsport
Old Apr 27, 2011 | 04:21 PM
Rogeyboy's Avatar
Rogeyboy
Oh dear lol!
Old Apr 27, 2011 | 08:02 PM
escort_matt
ofab,i done it my self,its got a fuel boost thing that im not sure how it works,
what makes you say its been to jamsport?
last time my car was touched by a tuner it was jano,but it was mfi at the time
Old Apr 28, 2011 | 08:53 AM
Versus_Creations
Ask me a question!
When it was on MFi it wouldnt of left my workshop running more than 3.5% depending on what mods it had and power it was capable of.
Matt, in general most people who do the EFi conversion on their own ends up with issues similar to what you have with co readings off the scale and the system not working as it should.
This is mainly down to people not using the correct loom and not wiring it in to the car properly, using secondhand parts that dont work and cant be checked easy etc..
I would advise having it checked out before you damage anything.
Old Apr 28, 2011 | 09:12 AM
phil_rs's Avatar
phil_rs
yam yammer
When Jamsport set my mfi s2 up, they set the co to 9%!
Old Apr 28, 2011 | 10:10 AM
Rogeyboy's Avatar
Rogeyboy
Jano all the online guides say the ofac/ofab is plug and play with an EFi XR3i loom... Ive been through the wiring diagrams and there don't appear to be any differences on Ofac and three wires to swap on ofab
Old Apr 28, 2011 | 10:16 AM
matthewsimone's Avatar
matthewsimone
Mine has always been running at around 3.2% althugh im buggered if ever need it adjusting as the little screw on metering unit is seized solid any tips on how to free it off greatly appreciated? tried soaking in wd40 etc but no joy, more I try undo it more the flat head screw rounds off
Old Apr 28, 2011 | 11:32 AM
Rogeyboy's Avatar
Rogeyboy
It shud b an allen key not a flat head screw...
Id fill the little tube up with wd40 or something if not, maybe you can access it from underneath - ive never looked!
Old Apr 28, 2011 | 12:44 PM
escort_matt
yeh it was on 3.5 at yours jano cos you showed me,the only second hand parts i got on it was loom and ecu,other then that its all new,just gota get the co right then its sorted,witch im hopin to do 2day
Old Apr 28, 2011 | 03:12 PM
matthewsimone
Yes I thought it should be an allen screw aswell actually oh well not to worry as so far its never needed to be adjusted in last 2 years of ownership
