Reyland Bells and Brackets
I bought these from Ian that had the Reyland Focos with the plan of making up a brake kit but ended up buying 380mm Alcons.
They are a 9" bell with brackets for use with a 362mm disc and Brembo Calipers.
£150
or with a set of Porsche Brembo 4 pot calipers that fit these mounts.
£400
The mounts look like they would be easy enough to mill some off if you were wanting to run smaller discs.
A moc up did with carboard 362 mm disc
£150
£400
OrionRST200bhp
Sep 29, 2015 08:30 PM
