And todays fault is ......
took the cossie out this afternoon, and todays fault is the temperature gauge
Sitting in traffic the gauge reads normal, but when driving the thing it barely gets off the bottom, and if I drive it from cold, it barely moves at all until it stands still for 5 mins. When I get to a giveway, the revs are sitting at 1200rpm (cold idle) once the gauge moves up, the revs drop to 900rpm. Now im thinking the car thinks its cold and is raising the idle. Its started since I fitted a thermostat from Burton Power last week. So im thinking the stat is stuck open and isnt holding any water in the head??
Anyone had this before??
Correct, it sounds as if the stat is stuck open or something else to do with it's wrong hence it never reaches the optimum temp, I assume it's the 82 degree stat you have brought?
Martin
Martin
Just removed the stat and put the old one back in which turned out to be a WAHLER 88deg stat. Worked perfectly, all back to normal now.
nipper.1
Ford KUGA
12
May 30, 2022 07:39 PM
rsguy
44
Sep 29, 2015 03:29 PM
