more fuel
Apr 25, 2011 | 07:36 PM
more fuel
at the moment i have bieges and a 044 fuel pump wat can i do to get more fuel to the engine wat flows more fuel then biege injectors ?
Apr 25, 2011 | 07:54 PM
Apr 25, 2011 | 09:00 PM
cheers do you know wat they flow ?
Apr 26, 2011 | 11:34 AM
Cossie yellows and greens?
Do they go straight in the EFi fuel rail?
Apr 26, 2011 | 07:35 PM
good point i assume so look the same
Apr 26, 2011 | 08:21 PM
i've got greys which fit the fiesta rail with no problems
Apr 27, 2011 | 11:35 AM
Martin & Luke - what management you running?
Apr 27, 2011 | 12:01 PM
Apr 27, 2011 | 05:49 PM
Apr 27, 2011 | 06:38 PM
megasquirt, tried ofab but its sh*t so i sold it then fitted megasquirt.
Apr 27, 2011 | 07:38 PM
Im tempted to go for MS too...
I dunno if they are "Greens" or not, i know they are green tho so maybe?
Apr 27, 2011 | 07:56 PM
Apr 27, 2011 | 07:58 PM
the problem is the cost to change the map on OFAB if want to change the imjectors or turbo etc.
Apr 27, 2011 | 08:01 PM
Yeah custom mapping is expensive once you get past the "stage1 and stage2" chips...
Il get mine to stage2 and then speak to MSD about a stage3 chip/map and go from there!
Apr 27, 2011 | 08:05 PM
the cost of a custom chip will pay for a megasquirt setup
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
