Engine bearings (ybb)
Old Apr 24, 2011 | 09:05 PM
opposite lock's Avatar
opposite lock
Default Engine bearings (ybb)
What ones are people using ? My engine is stripped and its got pinto bearings/shells , I,ve have heard from my engineer that Ford/Cosworth used ACL bearings in our engines. I,m going with the acl,s as thats the preffered route , we have heard other top engine builders do use pinto bearings in the cosworth engine, any thoughts and experiences?
cheers
Mike
Old Apr 24, 2011 | 09:35 PM
J1mbo's Avatar
J1mbo
B1mbo
If its on pinto shells make sure you get your crank sized properly to cosworth spec as cosworth and pinto shells are different!
Old Apr 24, 2011 | 10:01 PM
opposite lock
thanks J1mbo i,ll have a chat about that then , the last rebuild using pinto shells iirc the crank was ground 10thou . The crank is in good condition still, are you saying another regrind is likely or a definate to suit the different bearing?
Thanks mate
Old Apr 24, 2011 | 10:36 PM
J1mbo's Avatar
J1mbo
B1mbo
Yes I would say so mate, speak to your engineer to find out the correct size crank for shell, but they're deff different
Old Apr 24, 2011 | 10:56 PM
COLEYST200's Avatar
COLEYST200
Your 100% right there mate on pinto and cosworth sizes
Old Apr 24, 2011 | 10:58 PM
J1mbo's Avatar
J1mbo
B1mbo
Not just a pretty face coley
Old Apr 24, 2011 | 11:04 PM
phil_focus's Avatar
phil_focus
don't forget to do a dry build with plastigage to check ALL you bearing clearances, it will save you the suprize of "i just rebuilt my engine and its seized, what do i do?" !!!
Old Apr 25, 2011 | 07:56 AM
If the builder is any good, the sizes should all be checked anyway, inc the rods big ends for ovalty, make sure the block if being bored is done with a deck plate, if not go elsewhere.
I used ACL, nothing fancy in my engine, but every aspect of block was checked even for straightness, crank run on bearings etc.
Pay a little extra and get the mega heavy f/wheel lightened at the same time, you'll be glad you did when you drive it.
Why you not doing it yourself ?
Old Apr 25, 2011 | 11:20 AM
opposite lock
Doing what myself? build the engine you mean ? i dont think so chris!! I wouldn,t want to try tbh i dont seem to have the time for one nevermind all the tools and knowhow . The guy who i now am using is a very reputable engine builder that i know i can trust . My bores are fine just needs rehoning and yeah everything will be checked correctly using the correct methods i.e plastiguage.
If the crank needs a grind and theres already 10thou taking out how far can they go ? This engine will only likely see 350max with myself.
Old Apr 25, 2011 | 11:57 AM
RS SHAUN's Avatar
RS SHAUN
I've bought acl's for mine, Gordon Scott from Durham is building my bottom end!
Cheers shaun
Old Apr 25, 2011 | 02:32 PM
Unlikely to need another grind, hopefully if anything just a polish, but at 350bhp, you've got a few grinds left with total safety at this power level.
Old Apr 25, 2011 | 02:43 PM
opposite lock
As above Tabetha ^ looks as if it may need one. I dont mind as long as its all CORRECT this time round lol
Old Apr 25, 2011 | 02:58 PM
LHD220Turbo's Avatar
LHD220Turbo
kind of related, certainly interesting
https://passionford.com/forum/techni...-cosworth.html
Old Apr 25, 2011 | 04:42 PM
opposite lock
I make you right but i,m confused now lol . So ACL,s was not the chosen type from factory? Reading the link above suggests the old vandervals were used in cast form which mahle are reproducing instead now . I,ll be still using the acl bearing ( not sure if race or duraglide ) at this point as my engineer has recommended them and also afaik his opinion is the O.E bearing are acl,s. I,ll be discussing it with him tommorow anyway, cheers for the link LHD220turbo
Old Apr 25, 2011 | 07:14 PM
Mike,
I've just looked through my receipts, and now don't think mine were ACL's, but can't swear to it, I'll ask brian who supplied them as it is the same ones in their 10,000rpm race engines.
Old Apr 25, 2011 | 07:16 PM
J1mbo's Avatar
J1mbo
B1mbo
Would you think 10.000 rpm race bearings are good for the road tabs?
Old Apr 26, 2011 | 06:56 PM
opposite lock
Had a chat today with my engineer and he agree,s about pinto bearings be a different size , once all measured up we,ll know if a grind is likely.
Tabs , where you gone again lol !
Mike
Old Apr 27, 2011 | 04:22 PM
The rpms not really an issue, it's the load.
I found out today that mine most likely has GLYCO, or NEVLOK shells, 99% sure these are PINTO ones that they have used on all their cossie engines including the competition engines they warrant for as long as anyone can remember, they have had no failure to date.
Now thinking about it I seem to remember it was GLYCO in mine.
Old Apr 27, 2011 | 04:23 PM
Mike[/QUOTE]
I needed a poo, then accidentally the computer turned onto youporn.com, must get the compy looked at ha ha!!
Old Apr 27, 2011 | 11:22 PM
Paul_RS's Avatar
Paul_RS
Mines on Mahle bearings.
Aug 29, 2015 08:16 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
