Phase 3 1.5 vs 2bar.....
Old Apr 24, 2011 | 07:20 PM
mattygreen's Avatar
mattygreen
Default Phase 3 1.5 vs 2bar.....
I've not had my sapphire for very long and am taking it to a local tuners to have it rolling road'd on weds as when it was mapped it was live mapped, just curious as to what power it might be running????
Spec:-
bbr gas flowed/ported and polished cylinder head
bbr le manns cams
ported and polished inlet matched to head
throttle body matched to inlet
group A headgasket
t34 .48 with 360 bearing and cut back blades
3" system
dark green injectors
3 bar map sensor
BBR chip
It's ruuning 1.5bar/22psi at the moment - I'm hoping to up the boost to 2bar/30psi as long as fueling etc is ok, just wondering how much stronger it's likely to feel?
Old Apr 24, 2011 | 09:02 PM
crumpet's Avatar
crumpet
Pull alot harder!''should'' make at least 350 also
Old Apr 24, 2011 | 09:03 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
You need a bigger turbo and injectors to get the best out of that.
You might see around 350bhp if your lucky.
Steve
Old Apr 24, 2011 | 09:13 PM
crumpet's Avatar
crumpet
oo didnt notice your on greens and your head work, sell t34 and get a t38 with greys-siemens to get the best out of it
Old Apr 24, 2011 | 09:16 PM
mattygreen's Avatar
mattygreen
What sort of power could I expect from a t38?
Old Apr 24, 2011 | 09:20 PM
crumpet's Avatar
crumpet
steve above should know the max possible his Yb has made 470-480bhp from his spec
Old Apr 24, 2011 | 09:33 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Was 480bhp at 2.1bar boost.
Steve
Old Apr 24, 2011 | 09:40 PM
mattygreen's Avatar
mattygreen
That sort of power - gearbox issues? Will see how I get on weds, maybe t34 .63 and 400bhp first
Old Apr 24, 2011 | 09:42 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I had to have the gearbox rebuilt within 4 months of having the T38 fitted, and i only use the car once or twice a month lol
Steve
Old Apr 24, 2011 | 09:45 PM
J1mbo's Avatar
J1mbo
B1mbo
Keep everything the same don't change anything bar injectors
Put light blue injectors, re Mal and have 375/80 as it is
You will love it, one of the best road conversions we do everyone loves them, best in 2wd cars lol makes for good, instand punchy engine!
Old Apr 24, 2011 | 09:48 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Will you get that much on a .48 ?
Steve
Old Apr 24, 2011 | 09:50 PM
J1mbo's Avatar
J1mbo
B1mbo
Yes indeed
Old Apr 24, 2011 | 10:00 PM
JoeRS22's Avatar
JoeRS22
agree with jimbo, im running greys and t34.48 and got a very fun 365bhp
Old Apr 24, 2011 | 10:05 PM
mattygreen's Avatar
mattygreen
I'd be happy at that tbh... I thought greens were good for 380 and greys were for 400+?
Old Apr 24, 2011 | 10:16 PM
crumpet's Avatar
crumpet
greens 350-360, light blues 380-400, greys 400+
Old Apr 24, 2011 | 10:33 PM
J1mbo's Avatar
J1mbo
B1mbo
Greens around 340 realistically maybe a touch more
Blues on a very good spec engine 400
Greys 450
Old Apr 24, 2011 | 10:41 PM
mattygreen's Avatar
mattygreen
So at 1.5bar on greens - realistically it's running around 320bhp?
Old Apr 24, 2011 | 11:19 PM
crumpet's Avatar
crumpet
depending on the state of tune and condition yea if all in good order, .48 can make a reliable 360-370bhp and many people have said are awesome road cars in the past
Old Apr 25, 2011 | 07:49 AM
As with all things injectors vary enormously, I've had dark greens that were at 80% duty at 300bhp, I run a T3/34.48, for 300bhp @ 17psi, with same torque, boost starts at 1400rpm and full by 2500rpm so good road car, I don't go into this number chasing.
If it's been live mapped why are you having it done again ?
Old Apr 25, 2011 | 11:17 AM
mattygreen's Avatar
mattygreen
Car was live mapped by nms in 2007 - 4 years ago and has done 10k since, just curious as to the actual power it's putting out like I said. Also it was mapped to 1.9bar, 7200rpm limit and an afr of 11.9. Now only running 1.5bar, so guessing it's been turned down at some point? Not chasing any figures, just want the best out of it and get things checked again...
Old Apr 25, 2011 | 10:36 PM
crumpet's Avatar
crumpet
actuators probably fucked, or been dropped, never know whos been fiddling with it in 4 years! get it sorted asap
Old Apr 26, 2011 | 08:58 AM
Captain500rs's Avatar
Captain500rs
It peaks at 1.9 bar and holds 1.5 bar. Will find with most mapped cars you will have a peak reading and a lower figure that it holds. Ain't been turned down and nothing wrong with actuator.
Karl
Old Apr 26, 2011 | 07:58 PM
mattygreen's Avatar
mattygreen
Karl
I dare say that what it was mapped to that before as per my previous post...
As per Tony's add when I bought the car....
'the car is only running 1.4 peak dropping to 1.2 bar and is estimated by nms at 350/370 bhp so well within its capabilitys with scope for a lot more'
https://passionford.com/forum/cars-f...-recieved.html
It holds boost fine and dont doubt there's not a problem with the actuator, but it must have been turned down at some point... will see how I get on
Old Apr 26, 2011 | 08:10 PM
Paul_RS's Avatar
Paul_RS
Start saving for replacement gearboxes.
Old Apr 27, 2011 | 09:17 AM
Captain500rs
When I had the car Matty, it did what nms mapped it at. Only problem I had with it was when the wiring on the amal valve broke down at the plug, and stopped it holding boost properly. There is scope for more power, was mapped the way it was for reliability.
Old Apr 27, 2011 | 09:55 AM
Captain500rs
If its running at 1.5 mate its doing what its suppose to be doing when it was mapped. If you watch the gauge in 4th or 5th gear, it will go round to 1.9 and tail off to 1.5 and hold there. Cant see why Tony wrote that, must of been having a senior moment lol. Putting 2 bar through a T34 ain't gonna last long mate.
DixieTheKid
11
Jun 6, 2020 11:20 AM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
Caddyshack
Aug 19, 2015 07:29 PM
