s1 turbo same as s2?
Old Apr 24, 2011 | 06:22 PM
EscoVan's Avatar
EscoVan
Default s1 turbo same as s2?
as above are the turbo and manifold the same?
thanks dean
Old Apr 24, 2011 | 06:26 PM
stevealien's Avatar
stevealien
10 Year Member
think manifolds are the same mate,s1 turbo is not water cooled but s2 is.
there both same spec t3 though
Old Apr 24, 2011 | 06:51 PM
tunabob's Avatar
tunabob
Mmm right little sausage!
Same apart from the above . used to run s1 on my s2 just have to block off the water feed and return. Had mine on to lower water temps. but all in all will fit on. no props
Old Apr 24, 2011 | 08:28 PM
gaz s1's Avatar
gaz s1
s1 manifold sits closer to the block than a s2 as i found out to my misfortune when the s1 manifold hit my zetec block so had to use a s2 which clears the block!
Old Apr 24, 2011 | 08:55 PM
EscoVan's Avatar
EscoVan
so il be able to use an s2 turbo on a s1 engine? (and its for my van if that makes a difference)
Old Apr 27, 2011 | 08:25 AM
Cameron's Avatar
Cameron
Yes, if you dont want it to be watercooled you will have to block off the waterways on the turbo.
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
