Oil pump pressure release kit
Old Apr 24, 2011 | 04:58 PM
BRAMMER's Avatar
BRAMMER
Default Oil pump pressure release kit
I'm about to buy a pressure release kit and their are 2 rating available, just wanted to see if i anyone has any info on which kit is preferred on a standard C/R YB as more isn't always better?
Kit's are:
75psi cold or 85psi cold
Old Apr 24, 2011 | 05:27 PM
75 psi is more than enough, I have 100% bog std pinto pump on mine, all of Ł24, same as the one that was on it for 200k miles!!
Old Apr 26, 2011 | 05:30 PM
BRAMMER's Avatar
BRAMMER
Tab how do you get the cover off or is it just damage it to get it out as you have a new one to go in?
Old Apr 26, 2011 | 05:43 PM
Miller 3's Avatar
Miller 3
Is there actually any need to have a high pressure pump? sure i read some where Sheedy dont use them???
Old Apr 27, 2011 | 04:25 PM
No imo there's no need on 99% of cossies for a HP oil pump, if I was doing a lot of extended high revs in a restroked one I would but not in std/modified.
JK12
33
Apr 26, 2021 12:09 PM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
StephTell
Sep 2, 2015 06:31 PM
YODI
Aug 30, 2015 01:12 PM
