speedo cable gearbox oil leak
Old Apr 24, 2011 | 01:21 PM
TOMO's Avatar
TOMO
Default speedo cable gearbox oil leak
Is there an oil seal for the speedo cable? Can it be changed whilst its on the car? Is it common for these to go? Gear oil is spewing out from all around it.
Cheers Tomo
Old Apr 24, 2011 | 03:57 PM
there is a little dowl in to the gear box ,pull this out nearly all the way with some mole grips, then the whole lot should pull up out of the box, there is a rubber o ring on the speedo drive this may have perished ,or check your dowl is in properly as the speed drice may not be in properly giving you a leak ,can be done while in place ,funny enough just had mine out
Old Apr 25, 2011 | 07:36 AM
TOMO's Avatar
TOMO
Awesome, Twins your the man the roll pin/dowel on the box near the cable is nearly all the way out. So should i just push down on the speedo assembly and nock it in, or take it out replace the O ring and then nock it in?
Old Apr 25, 2011 | 02:16 PM
As its out, take it out and inspect it anyway ,make sure the flat part on the drive lines up with the dowl when putting back in, and you dont have to knock the dowl right back in leave a bit out, to grip in future
Old Apr 25, 2011 | 02:18 PM
if you can pull it out with out removing the dowel more, chances are this was the cause as the drive would have been jumping up and causing a leak
Old Apr 25, 2011 | 07:18 PM
TOMO's Avatar
TOMO
Cheers for the help mate ive sorted it now, fingers crossed I get no more drips. Especially as ive just had the box out and put a new clutch and end gearbox endcap gascket on, I thought it might be leaking from where the bell housing bolts to the gearbox aswell but I guess time will tell.
TPM961
Jan 15, 2018 10:50 AM
Bransby
Sep 14, 2015 08:54 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
Adam Graham
Sep 6, 2015 06:04 AM
gingeRS
Sep 4, 2015 06:29 PM
