Fiesta Turbo Conversion
Old Apr 21, 2011 | 10:07 PM
Stevie RS Boy's Avatar
Stevie RS Boy
Default Fiesta Turbo Conversion
I have a P Reg mk3 fiesta and want to do a turbo conversion on it, i know i will have to change brakes suspension etc, whats the wiring like to change? and anything elsed i need to know please
Old Apr 27, 2011 | 01:09 PM
Stevie RS Boy
will it be easier to change the whole loom or splice into the old one?
Old Apr 27, 2011 | 07:54 PM
JJ24's Avatar
JJ24
Hey buddy, im not a mechanic but it all depends what model it is i.e XR2i, Ghia, etc etc. But i would have thought you would have to change the whole loom as your car is alot newer than the RS Turbo's. I could be wrong lol. Jamie
Old Apr 27, 2011 | 09:37 PM
jon_ross's Avatar
jon_ross
unless your very good with wiring you will not get past the pats system in your car and if you manage to find some one that can it will cost you alot more than a rs turbo loom would and they are very easy to fit too all you have do is strip the interior and dash out. i have a good rst loom if you need it. its complete and labeled up ready to fit, jon
Old May 13, 2011 | 07:47 PM
Churtz's Avatar
Churtz
Pats is easy to bypass. Just run the ign wire from barrel to the starter relay. Done.
Matt
Old May 29, 2011 | 08:51 PM
Stevie RS Boy
i'm going to change over the wole loom, shouldnt be a problem, just trying to source all the bits i need
Old Jun 7, 2011 | 07:05 PM
AWOL's Avatar
AWOL
Engine Builder
Matt
what about the fuel pump???? wiring to the ig. relay will run untill its used the fuel left in the line
Old Jun 7, 2011 | 09:23 PM
Ben26's Avatar
Ben26
just buy a FRST , done !
Old Jun 15, 2011 | 09:11 PM
Stevie RS Boy
yes that would be easier, but how many P plate rs turbos are around and i like a challange, a wolf in sheep clothing
Old Jun 15, 2011 | 09:58 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
im gessing you are talking about wiring up ofab or ofac?? its easy around 6 wires i converted my apprentises mk2 fiesta. he fitted the engine in his spair time and when it was in and he had plumbed in a fuel system i wired a xr2i ecu and loom up for him
Old Jun 27, 2011 | 10:05 PM
mrjenrst's Avatar
mrjenrst
None and there never will be!
Old Jun 30, 2011 | 08:48 PM
Stevie RS Boy
i know they werent produced on a P reg, thats one reason why i want to do a conversion
Old Jul 2, 2011 | 08:42 PM
mrjenrst's Avatar
mrjenrst
but you cant convert it to an rs your just putting a different engine in.
It'd be better to drop a cvh turbo in it and make it a sleeper, rather then having replica. All imho.
Old Jul 2, 2011 | 08:44 PM
mrjenrst's Avatar
mrjenrst
or you just dropping a turbo lump in?
Old Jul 16, 2011 | 05:52 PM
Stevie RS Boy
im just dropping a rst engine and running gear in with steel wheels, a nice little sleeper
Matt Baxter
Sep 16, 2015 08:30 PM
Ben26
Aug 27, 2015 08:56 PM
paceo
Aug 27, 2015 12:45 PM
turbobill
Aug 1, 2015 08:55 PM
