the good old noisey cat heat sheild problem!
Old Apr 19, 2011 | 08:46 AM
st170dan's Avatar
st170dan
Default the good old noisey cat heat sheild problem!
does anyone know if replacing both the upper and lower part of the heat shield cures the rattling problem? ive read about using cable ties and that reduced the problem but didnt eliminate it. ive subsequently removed the lower part as it was looking a bit knackered. both heat shields and bolts are £70 from ford :/ would like to know if it actually works before i splash the cash.
Old Apr 19, 2011 | 10:18 AM
CoupeUK's Avatar
CoupeUK
With my ST170 I had the same problem, stainless cable ties cured it for a short while but then it came back again so I pulled them off. No problems with no heatshields in 40k
Old Apr 19, 2011 | 10:24 AM
st170dan's Avatar
st170dan
yeah i know its ok without but im becoming increasingly more ocd with my car and would prefer it to be as its meant to be.
Old Apr 19, 2011 | 12:57 PM
Sp3no's Avatar
Sp3no
I ripped mine off once it started to rattle another cause is if the Cat bracket has snapped off the cat, this can cause a similar noise.
Old Apr 19, 2011 | 01:05 PM
st170dan's Avatar
st170dan
ok cool, il have a poke around next time im under there.
Old Apr 21, 2011 | 11:06 PM
fordsrus's Avatar
fordsrus
I am having the same problem. Thought it was coming from the exhaust manifold shield because that is very loose. Sorted that out and it is still really bad. Is it the heat shield above the cat that normally causes this rattle then?
Old Apr 21, 2011 | 11:44 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
I was only looking for a cure for this yesterday. Anyway I found this link.
Problem:
Cure:
Old Apr 27, 2011 | 09:33 PM
st170dan's Avatar
st170dan
yeah i did this /\ but it didnt work fully.
Old Jun 7, 2011 | 08:39 AM
st170dan's Avatar
st170dan
im just wondering if i remove the top part of the heat shield if i could wrap the cat in heat wrap?
markk
Dec 2, 2021 06:59 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
track.focus'd
Aug 12, 2015 05:53 PM
Old ford
Jul 31, 2015 06:50 AM
