Ford Fiesta Mk6 tail light upgrade
Old Apr 9, 2011 | 10:43 PM
Ebz_09's Avatar
Ebz_09
Default Ford Fiesta Mk6 tail light upgrade
Hi everyone Im new to all this and im just trying to do a few mods to my MK6 fiesta to get it looking like the MK6 face lift version.
I was just wandering if the stock rear tail lights on the face lift version will fit the non face lift version... I understand that there is an extra break light on the face lift version.
What do I need to purchase apart from the actual light set to get it to work as Im assuming its not just plug and play.
Thanks in advance
Old Mar 17, 2013 | 12:57 AM
Owen Adam Marshall's Avatar
Owen Adam Marshall
Thanks in advance
Hello, I've done this conversion my self to my fiesta the plugs are completely different to start with so i made little connectors and joined them together plus the reverse light had to be wired in on bother sides so i ran a wiper under the trim in the boot, the side light also got ran through the boot, for the bottom of the light unit's you need the pushed in grommit to hold it in place otherwise it is insecure. Good luck
Botts
Aug 13, 2015 04:16 PM
sridgett
15
Aug 3, 2015 07:26 PM
