TPS for P8
Old Apr 9, 2011 | 08:37 PM
driven7's Avatar
driven7
Default TPS for P8
hi guys ....
I have a problem with a chip, I think it can be this bad TPS. need text, but I've seen that has various positions (1 cm up / down).
resistance varies according to the position, as should be all right?
few (volt / ohm) must have?
thanks
Old Apr 10, 2011 | 06:56 AM
oldford's Avatar
oldford
Idle position is self-learning (within limits) so a small variation has no effect.
Set idle position to 0.15 to 0.20 volt.
Check full throttle signal, should be at least 4.5 volt.
Old Apr 10, 2011 | 09:29 AM
grcossie's Avatar
grcossie
http://www.cannell.co.uk/Ford_Worksh...sis%20Info.pdf
Old Apr 11, 2011 | 02:36 PM
driven7's Avatar
driven7
many thanks you
DixieTheKid
11
Jun 6, 2020 11:20 AM
muffster
13
Sep 3, 2015 09:40 PM
cozzy jeff
Aug 31, 2015 04:14 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Roosie
Aug 15, 2015 08:09 PM
