Mondy V6 onto fiesta diesel box, will it fit?
Apr 6, 2011 | 10:11 AM
I'm after putting a mondeo V6 into my fiesta, do you know if they will go onto a fiesta box, and if so do I need a 1.8 clutch??
Thanks
Dave
Apr 6, 2011 | 10:21 AM
nope, different bellhousing bolt patterns. and no the 1.8 clutch is too small. you need to go v6 mtx75 gearbox
Apr 6, 2011 | 10:31 AM
So if i get a fresh 2.0 blacktop and use a 1.8 sump and clutch I should be alright?
Apr 6, 2011 | 10:39 AM
Quote:
Originally Posted by
mobb-black
I'm after putting a mondeo V6 into my fiesta, Thanks
Dave
mobb-black
Not quite a v6 then!, you need 1.8 sump, flywheel and clutch, then it will work
Apr 6, 2011 | 11:01 AM
fancy a daft engine but dont like the way turbos drive
Apr 6, 2011 | 11:11 AM
go the v6 route with the v6 mtx75 gearbox would be good to see
Apr 6, 2011 | 11:53 AM
or 6 speed from the st220
Apr 6, 2011 | 12:12 PM
I'd love to do that, I just can't weld. I can do everything else mechanically, its just welding I struggle with.
Apr 6, 2011 | 12:49 PM
You need to use the mondeo box. My mates got a V6 powered Xr2i on omex
Apr 6, 2011 | 12:51 PM
did it go in as a unit on custom mounts and shafts
Apr 6, 2011 | 01:13 PM
He had to make custom engine mounts and cut the panel in the front arch to clear the gearbox. I think he is going to turbo charge it this year aswell.
Apr 6, 2011 | 02:57 PM
yeah i thought it'd need a lot of work
Apr 6, 2011 | 04:52 PM
as said v6 mtx75 gearbox and then get custom shafts made.
if you get it to locate like my frs box on my zetec xr2 then i'll give you sizes of driveshafts to get made up if that helps at all.
Apr 6, 2011 | 08:25 PM
thats cool, thankyou. I'll have a look and see how much engines are
Apr 7, 2011 | 05:21 AM
The engine management will be the biggest challenge/expense.
Apr 7, 2011 | 06:30 AM
Yeah, the plan was always to do the mechanicals and then give it somewhere to put a loom and management on
Apr 7, 2011 | 06:37 AM
custom mounts and shafts are a bit beyond me i think. My car has a 2ltr already, but the engine is a duffer and missing 75% of its bits. Am planning on pulling it out at the weekend and finding another focus 2.0, a friend has already welded 2.0 mounts in for me so i guess i may as well go with that.
Chas
Sep 21, 2015 08:57 PM
matman
Sep 9, 2015 05:45 PM
druidgetafix
Aug 15, 2015 10:22 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
