3 button key fob
Old Apr 6, 2011 | 08:13 AM
terry203's Avatar
terry203
Default 3 button key fob
hi folks just a quick question my 3 button key fob wont work even with a new battery if i was to buy a replacement off ebay have the serial numbers got to match?
found 1 but just the last letter is different
cheers
Old Apr 6, 2011 | 10:49 AM
sykes2009's Avatar
sykes2009
im not sure but i dont think they need to match its more of the key will need coding to your car and its not cheap
Old Apr 6, 2011 | 12:01 PM
terry203's Avatar
terry203
cheers for the reply
iv been told i can programme the key myself dont no how true that is ill give it a go cheers
Old Apr 6, 2011 | 12:46 PM
martysmartie's Avatar
martysmartie
Programming can be done yourself, think as long as it's the same type of key, I.E on the same radio frequency etc you should be ok.
Martin
Old Apr 6, 2011 | 12:58 PM
terry203's Avatar
terry203
cheers ill give it a go
Old Apr 7, 2011 | 05:52 PM
woolford's Avatar
woolford
Put key in an turn ignition on an off three times without starting the car will beep then press ya key should sync
Old Apr 7, 2011 | 07:08 PM
Chaz888's Avatar
Chaz888
I thought the key prog system is to programing new pats keys not the remote setup?
Old Apr 7, 2011 | 08:06 PM
martysmartie
No you can do both yourself, with the remote part you have to press button couple of times IIRC, whilst in learning mode.
Martin
Old Apr 7, 2011 | 08:27 PM
Chaz888's Avatar
Chaz888
Martin
nice one marti did not know that ! so if when i use my st200 engine an keys with remote I can re-prog that to my car ?
Old Apr 7, 2011 | 10:07 PM
woolford's Avatar
woolford
Rite lets get this right if I buy a key off eBay I can programe it myself?? How?
And if I get a ket cutter to cut my key it will Work?? So this can be done for about £20 were as for charge over £150???
Old Apr 8, 2011 | 10:02 AM
terry203's Avatar
terry203
iv ordered a key off the bay ill let u all no how i get on
Old Apr 10, 2011 | 01:57 PM
terry203's Avatar
terry203
got new key off the bay with the same serial number followed all the steps to program it but no joy
anyone hav any suggestions
Old Apr 10, 2011 | 02:22 PM
thebigmacmoomin's Avatar
thebigmacmoomin
I used to use a Jaguar S / X Type key on my old Mk1 Focus 5dr. Just programmed it the way it tells you in the manual. The Jag key worked on my 5dr but not on my 3dr for some odd reason.
Old Apr 12, 2011 | 07:17 AM
terry203's Avatar
terry203
just took the key to have it tested and its not sending a signal ? is the red led surpose to light up on the key fob coz mine isnt so this could be the problem
Old Apr 12, 2011 | 07:41 AM
martysmartie
I recently worked on a Galaxy (Two button), don't know if yours is the same but be very careful, I tested the battery and it was fine, thinking it can only be the battery I got a replacement, fitted it only to find it still did not work, I found this very strange, I eventually figured out that there is in fact TWO batteries, when I removed the first there was a metal plate beneath which I thought to be the contact plate but once removed there is another one beneath, once this one was replaced all was well!
Yes red LED is supposed to illuminate when button is pressed!
Martin
Old Apr 12, 2011 | 08:24 AM
terry203's Avatar
terry203
iv checked and the focus key only has 1 battery
led isnt lighting so must b a bad connection cheers
Old Apr 12, 2011 | 08:27 AM
martysmartie
Is the battery good?
Martin
Old Apr 12, 2011 | 08:33 AM
terry203's Avatar
terry203
yeah brand new also when i got the replacement key the seller added a new battery aswell
tankybaby66
Feb 6, 2016 02:24 PM
A.t.p
Oct 23, 2015 07:54 PM
TC-ST3
Sep 26, 2015 04:47 PM
Iain Mac
Sep 13, 2015 09:16 PM
NC53
Sep 13, 2015 03:05 PM
