T5 gearbox lever noise
Old Apr 5, 2011 | 08:22 PM
brooksy898's Avatar
brooksy898
Default T5 gearbox lever noise
hello to all, ive noticed when moving the gear lever side to side in neutral it makes a strange noise. Is this normal or sumit serious.
Many thanks
Old Apr 6, 2011 | 07:13 AM
Depends where the noise is coming from, the lever cup can get dry if well used and grate a bit, but certainly NO noise should be heard from inside the box itself..
Old Apr 6, 2011 | 09:56 AM
brooksy898's Avatar
brooksy898
thanks for the reply, the noise sounds like its coming from the lever joint.
Here's a video of the noise= http://www.youtube.com/watch?v=zq3o0Mi-vOI
Old Apr 6, 2011 | 07:08 PM
I assumed you meant in the car engine running etc, that noise is 100% normal, just it's not heard with the layers of rubber gaitor and leather gaitor on the car in use.
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
gingeRS
17
Oct 2, 2015 09:42 AM
Iain Mac
Sep 30, 2015 09:39 PM
