block, rocker cover + more...Can Bring To Central Day
Old Apr 5, 2011 | 07:51 PM
RS-Leigh's Avatar
RS-Leigh
Default block, rocker cover + more...Can Bring To Central Day
The last bits I have in the garage, can bring to Central day on Sunday.
205 Wire ringed block by NMS, bores are +0.5mm
£250 ono
Rocker Cover in crackle finish VHT Red, breather hole with hose connection, bayonet oil cap
£60 ono
Piper BP270 HYT cams, very similar to the BD10 - 4wd cams but come with the collars to fit to a 2wd head.
http://www.pipercams.co.uk/pipercams...n=8&engine=133
£125 for both
2wd Exhaust manifold and trousers, no cracks
£55 ono
4wd Gearbox cradle and gear stick with new bushes ready to fit
£45 ono
4wd Rear Prop Shaft
£50 ono
4wd Front Prop Shaft
£35 ono
4wd Cross member ( has ARB and Steering Rack fitted)
£50 ono
Everything is excluding postage.
Thanks
Leigh
bigryrs
Aug 29, 2015 10:51 AM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
borboyous
Aug 22, 2015 11:17 AM
JoeyBoyden
Aug 18, 2015 10:52 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
