best cams for 400+ gt30.
Old Apr 4, 2011 | 12:30 AM
crumpet's Avatar
crumpet
Default best cams for 400+ gt30.
as above, been searching through for bd14's etc but read they would collide with the pistons unless 4x4 or pocketed pstons are used?
spec:
Gt3071r
swedish plenum
2wd head
205 bottom end
Would the best be a bd14 inlet and STD exh, or would 400-420 be possible on a standard head+cams?
Old Apr 4, 2011 | 05:12 PM
Nash's Avatar
Nash
Cake lover!
Do a search for AB07 cam, this will do what you want.
Old Apr 4, 2011 | 05:14 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Good cam and works without valve cutouts
Steve
Old Apr 4, 2011 | 05:19 PM
Staffi's Avatar
Staffi
Old Apr 4, 2011 | 05:30 PM
BRAMMER's Avatar
BRAMMER
The AB07 is the only decent cam you will get unless you speak to one of the big tuners regarding a custom cam
Old Apr 4, 2011 | 07:46 PM
crumpet's Avatar
crumpet
What spec lift is a ab07 similar to? cheers il search here for them now, theyre expensive though compared to Bd's are they not?
Old Apr 4, 2011 | 08:19 PM
BRAMMER's Avatar
BRAMMER
Similar to a BD14
Old Apr 4, 2011 | 08:23 PM
crumpet's Avatar
crumpet
cheers for them bram, would it still be making power at 6500+ and is that correct the bd14 has .017 more lift? Does this effect performance much?
cheers
Old Apr 4, 2011 | 08:38 PM
Nash's Avatar
Nash
Cake lover!
Tbh you don't have alot of choice if your not running pocketed pistons. Mine was still making power at 6.8k on a T4 with this cam. I have built a new engine with pocketed pistons and have decided to keep my AB07 cam, having been out in T4 cars running BD16's, i feel the AB07 makes for a nicer drive on a road with the way the power comes in.
Old Apr 4, 2011 | 08:39 PM
KSA-Cossie's Avatar
KSA-Cossie
AB07 = magic cam
Old Apr 4, 2011 | 08:48 PM
crumpet's Avatar
crumpet
take it theres alot more torque made from the standard inlet cam then, would the swedish plenum make a difference also?
How much did you guys pay for yours if you dont mind?
Bd's are cheap compared to the 256's i bought for my starlet.
cheers
Old Apr 4, 2011 | 08:53 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Have you fitted yours yet Kev ?
Steve
Old Apr 4, 2011 | 08:56 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
cheers
The AB07 is a win win cam on both power and torque.
I lost no bottom end power or torque when i had mine fitted and made big gains in both higher up running the same boost.
If you do a search you will find my graphs before and after the cam was fitted.
Steve
Old Apr 4, 2011 | 09:01 PM
KSA-Cossie's Avatar
KSA-Cossie
Steve
Was just done on Friday there Steve.
Old Apr 4, 2011 | 09:02 PM
Nash's Avatar
Nash
Cake lover!
I didn't think 438lb/ft was bad tbh.
Old Apr 4, 2011 | 09:06 PM
crumpet's Avatar
crumpet
Boost were you running with that nash, the good thing is a gt3071 comes on boost earlier than a t4
Old Apr 4, 2011 | 09:24 PM
BRAMMER's Avatar
BRAMMER
Interesting as i'm in two minds about rebuilding mine again with pockets and that was the inlet choice but.....
What you think Kev?
I've only been in one T4 car, don't even think it was running full potential but lets just say it comes on boost that hard i seriously didn't believe the brakes could stop it if they needed to - they are an awesome turbo on the right engine
Old Apr 4, 2011 | 09:39 PM
KSA-Cossie's Avatar
KSA-Cossie
What you think Kev?
Not driven it yet Chris
Old Apr 4, 2011 | 10:05 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Here is the before and after graphs
Steve
Old Apr 4, 2011 | 10:15 PM
crumpet's Avatar
crumpet
fookin hell steve that power comes is alot earlier and harder!Nearly 100ftlbs more torque?! bet it pulls Very well
Old Apr 4, 2011 | 10:25 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Like i said its a good cam
Both graphs are with the same boost as well.
The RPM scale is a few hundred rpm low on the second graph.
It now has a few more ponys and will spin the wheels in 3rd at 80 lol
Steve
Old Apr 4, 2011 | 10:41 PM
1374lee's Avatar
1374lee
Ab07 is an excellent cam and offers both power and torque increases throughout the range without compromising bottom/mid range torque.The bd series of cams are now old hat,not saying that they are not good but a lot of modern tuners these days say there are far better cams developed since the bd series.
Thanks.Lee.
Old Apr 5, 2011 | 07:43 AM
Turbosimpsons's Avatar
Turbosimpsons
mine had a ab07 cam fitted by Turbosystems since 1994. so not as new as you think.
Old Apr 5, 2011 | 07:55 AM
JamesH's Avatar
JamesH
What you really want is Mark Shead's inlet cam for the GT30
Old Apr 5, 2011 | 08:29 AM
Nash's Avatar
Nash
Cake lover!
Thats odd as when Ahmed mapped my car in 2007 he recommend fitting one of his new cams he had just designed, Ahmed said he had just finished testing them. How sure are you that urs is an AB07 and not a CW1?
Old Apr 5, 2011 | 08:31 AM
Nash's Avatar
Nash
Cake lover!
27-28psi.
Old Apr 5, 2011 | 08:59 AM
BRAMMER's Avatar
BRAMMER
James you only read good things about his inlet cam but you can't buy one off the shelf as such can you?
So unless your having a complete engine build or aftermarket management they are not available
Old Apr 5, 2011 | 11:14 AM
JamesH's Avatar
JamesH
Chris,
I believe Mark will sell you one providing he times the engine up Not sure if he would need to map it also, or whether he's happy for you to let someone map the Weber for you. Give him a bell he'll soon tell you
Old Apr 5, 2011 | 05:23 PM
DAN400's Avatar
DAN400
the guys i use are the autronic dealers for n ireland and are big with mark, mark said he will supply me one off his cams as long as they fit and time it in,
which is nt a problem
Old Apr 5, 2011 | 06:03 PM
Paul_RS's Avatar
Paul_RS
They'll probably blow your engine up though
Old Apr 5, 2011 | 06:12 PM
peteh's Avatar
peteh
am i the only plum that had no idea AB stood for ahmed bayjoo?!?! lol
Old Apr 5, 2011 | 06:16 PM
Staffi's Avatar
Staffi
PLUM................
Old Apr 5, 2011 | 06:21 PM
peteh's Avatar
peteh
balls! haha
Old Apr 5, 2011 | 06:22 PM
Staffi's Avatar
Staffi
Pete, tbh mate i didn't know myself.....
I've only heard great things about them though..
Old Apr 5, 2011 | 06:25 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
That they are
I wounder what a pair would be like ??????
Steve
Old Apr 5, 2011 | 06:30 PM
peteh's Avatar
peteh
haha not just me then you plum!
cossie4i - what's your actual engine spec? i can read what's in your sig but what else, standard bottom end etc etc?
Old Apr 5, 2011 | 06:38 PM
Turbosimpsons
cuz iv'e just changed it for a bd16 at Turbosystems. it had got ab07 stamped on the rear of the cam.
Old Apr 5, 2011 | 06:40 PM
Turbosimpsons
That they are
Steve
whoooo er nice pair.
i had a pair in mine still got the ex cam in.
Old Apr 5, 2011 | 06:51 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Standard bottom end, well slightly lower comp and still on a 205 block.
Steve
Old Apr 5, 2011 | 10:05 PM
DAN400's Avatar
DAN400
why whos engine did they blow ?
