Saff 2wd Engine Mounts ... what to go for?
Old Apr 3, 2011 | 08:00 PM
ThomasV's Avatar
ThomasV
Default Saff 2wd Engine Mounts ... what to go for?
Hi fellas,
Still having trouble with my saff shaking/rattling around 3.000 rpms.
It does it in gear, when driving, in neutral and with clutch pressed down, so pretty much all the time.
It starts at approx 2.500 rpms and starts to go away at around 3.500 rpms.
I have had the gearbox mount replaced, but had no effect.
Since the problem also occurs in neutral and with clutch pressed down, then I believe this rules out diff and gearbox. I would think that the shaking / resonance can only come somewhere from the engine and now I will try to replace the engine mounts, even though these are only about 1 year old and "looks" fine.
What do people recommend ? .... OEM or Collins uprated ?
Car runs stage 3 ...
BR
Thomas
Old Apr 3, 2011 | 08:12 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
nothing wrong with standard ones if yours are no good get new standard
Old Apr 4, 2011 | 09:47 AM
ThomasV's Avatar
ThomasV
Cheers mate ... might just do that, however the Collins ones costs almost the same as a new set of OEM, so does anyone have good/bad experiences with them ? ...
Word around town is, that they don't cause vibrations like many other uprated ones will do.
Old Apr 4, 2011 | 11:18 AM
Char1ie's Avatar
Char1ie
I wouldn't replace them unless you know they are perished. Are you sure that it's the engine mounts causing the vibration? Could be prop related.
Charlie
Old Apr 4, 2011 | 11:51 AM
Stu @ M Developments's Avatar
PassionFords Creator
That is correct, they dont. The shore hardness is just right on them.
Plenty in stock here too.
http://shop.motorsport-developments....arts-164-c.asp
Old Apr 4, 2011 | 12:15 PM
ThomasV's Avatar
ThomasV
@ Char1ie
If it was prop related, then it shouldn't have the vibrations in neutral.
I have also tried to drive the car to until the vibrations are there, and then push down the clutch and let the car roll ... then the vibrations are gone.
@STU
Sounds really good Stu! ... guess this is my next move then. If this doesn't help, then I might have to look at flywheel and clutch ... might be some sort of in-balance there.
Old Apr 4, 2011 | 12:25 PM
Dont forget to claim your members discount from my shop mate, use the code "PFDiscount"
Old Apr 4, 2011 | 12:33 PM
ThomasV's Avatar
ThomasV
Way ahead of you Stu! ... already ordered and paid for them, with the discount-code.
Old Apr 4, 2011 | 12:49 PM
Brilliant, thanks for your continuing business Thomas.
Old Apr 4, 2011 | 01:15 PM
ThomasV's Avatar
ThomasV
No problem, mate ...
Old Apr 4, 2011 | 01:31 PM
RS SHAUN's Avatar
RS SHAUN
Get some pics of your saph up Thomas!
Cheers shaun
Old Apr 4, 2011 | 01:40 PM
ThomasV's Avatar
ThomasV
Cheers shaun
Still a work in progress, mate ... but here is a few quickies.
mk22door
49
Mar 26, 2022 07:15 AM
track.focus'd
Aug 12, 2015 05:53 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
lockie
Jul 31, 2015 10:03 PM
Old ford
Jul 31, 2015 06:50 AM
