AB07 inlet valve clearance
AB07 inlet valve & piston clearance question
I have spoken to Kent regarding the clearance and this is the info i was given - what i was asking was did they produce this cam with clearance on skimmed heads and here's the info i was given:
9 thou (1/4mm) TDC and 2mm valve drop
So from the info i was given what would be the last size head it would work without pockets?
I run standard Cosworth pistons and a Grp A gasket
Should have phoned them first actually but didn't think, will phone them tomorrow Adam
So what he basically said was if it doesn't drop and sit on the piston at TDC with at least 2mm of travel then they will touch when running at full rpm of 6500 i think that is right
07-10-2015 12:56 PM
Johnny Knoxville
30-09-2015 07:21 AM
