ABS Warning Light Deactivate...
Old Apr 3, 2011 | 07:56 PM
Heathen's Avatar
Heathen
From: A Small Island Somewhere In The South Pacific
Default ABS Warning Light Deactivate...
My Car has failed its' Warrant Of Fitness (New Zealand) because the ABS light started flashing during the inspection...
I've read here that it can often just be dirty sensors etc. However, I really just want to deactivate the light as I know the brakes work fine.
Is there a quick way of doing this without taking the bulb out from behind the gauges/dashboard?
Old Apr 3, 2011 | 08:05 PM
Heathen's Avatar
Heathen
I read this in another thread:
'Well my ABS is deactivated at the moment and it feels just the same as before, only that the wheels lock up. I would imagine completely unplugging one of the wheel speed sensors would do the job.'
By simply unplugging one sensor, will that deactivate the whole ABS system (including the dash light)?
BTW, the problem is in a '90 Sapphire.
Old Apr 3, 2011 | 08:44 PM
martysmartie's Avatar
martysmartie
Removing a wheel sensor will NOT extinguish the light, it will do the complete opposite and illuminate the bulb as the ECU will not see the expected voltages generated. There is a way of doing it however you should find the cause, more than likely what you say as the car shoulden't pass the MOT as the ABS isn't working!
Martin
Old Apr 3, 2011 | 10:45 PM
Heathen's Avatar
Heathen
Something else I forgot (if it's relevant)...
The light has never been a problem for me. It comes on as normal when the Car first starts then goes off till the next time I start the Car.
It only started flashing when the guy inspecting it put it on the rollers to test the brakes.
Old Apr 3, 2011 | 10:52 PM
martysmartie
Your best off Pming "Jon@work" off here as he knows the system inside out. It may be one of the brakes is binding etc and so that wheel is spinning slower than the rest that or a sensor problem I should think.
Martin
Old Apr 3, 2011 | 11:00 PM
Heathen's Avatar
Heathen
Thanks, Marty!
I'll try that now...
Old Apr 6, 2011 | 05:21 AM
Heathen's Avatar
Heathen
The light is on all the time now...does that give any more of an idea of what could be wrong?
The brake machine at the testing station read that all my brakes were working well with very little discrepancy between left and right stopping power.
Old Apr 6, 2011 | 08:27 AM
chrisa3's Avatar
chrisa3
If the light started flashing during a brake test, it could be either a pressure problem or fluid level. The light stays on when you turn the ignition be cause the pump starts, the light will go out when the system is upto pressure. The light can also be triggered by a low fluid level.
First thing to check would be the fluid level. if its fine and the light is still on, try and disconenct the two pin plug on the reservior cap and bridge the two pins with some wire and see of the light goes out. If it does, its a faulty level sensor.
After this, try jon@work, the guys a ABS system guru
Old Apr 6, 2011 | 10:16 PM
Heathen's Avatar
Heathen
Sorry, Chris...I forgot to mention that in my last post.
I had already P.M'd Jon and he said the same thing, check the fluid level first. I did that, but the light is still there (although the fluid was a little low).
Thanks alot for the info about two pin plug. I will go and try that now!
Old Apr 6, 2011 | 10:20 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Don't Ford systems auto-test everytime you start the car, so there's no way of turning the bulb off without either fixing the fault, or taking the bulb out?
Old Apr 7, 2011 | 10:55 AM
So has your light stayed off now then or is it back on. If i was you i would be doing a visual check of the abs sensors. The back ones corrode badly.
Old Apr 7, 2011 | 04:03 PM
Paul_RS's Avatar
Paul_RS
If you have a problem with the pump/ecu/a sensor is disconnected, the light will be on constantly.
If you have a dodgy sensor, thats still seen by the ecu, but gives the wrong reading whilst driving, then it'll only bring the light on over 5 or 10 mph (can't remember the exact figure lol)
Old Apr 7, 2011 | 06:17 PM
martysmartie
Most ABS systems do, thats what the MOT part is about making sure the light extinguishes after it's done a diag.
Whats mentioned above is the sensor in the master cylinders that these have, by bridging the wiring connector, if the light extinguishes it shows the sensor is at fault.
The above being said if it were low fluid level it will also illuminate the fluid warning light as well, if ABS light is on solo it indicates a ABS system mal function.
Martin
Old Apr 8, 2011 | 10:19 PM
Just give your rear sensors a check over.These were mine which were bringing the light on straight away when i started the car up.
Old Apr 19, 2025 | 01:42 PM
Tim Wharton's Avatar
Tim Wharton
Default ABS issues
Hi
The main thing if you are contemplating changing the Accumulator or the pressure switch is to make sure you have depressured the system first
Take the key out of the ignited don't switch back on till repairs are completed
Next pump the brake pedal 20 times so the pedal is solid with no assistance .
Then when you remove either item expect to get a cerain amount of fluid loss .
After replacment switch the ignion back on and dont touch the pedal until the pump cuts out.
More likely to be the pressure switch.
Good luck Tim
Old Apr 20, 2025 | 11:44 PM
rick o'shea's Avatar
rick o'shea
Holy thread revival Batman !!!
Old Apr 21, 2025 | 10:16 PM
THE RADMAN's Avatar
THE RADMAN
only 14 yrs late
muzzman1
Sep 30, 2015 08:59 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
