Peugeot brembos and discs on a saph?
Old Apr 1, 2011 | 09:31 PM
ram's Avatar
ram
Has a large member
Default Peugeot brembos and discs on a saph?
Hi guys
Got a mate at work whos breaking a peugeot v6 coupe so im having the brembo calipers with pads off him (for £80 quid ) Just wondering if the discs will fit too as i know theyre the same 4 stud pattern as most fords.
Also anyone know if where i can get hold of the brackets needed to fit them? remember someone on here selling them a few months ago.
Old Apr 1, 2011 | 09:50 PM
fraser9764's Avatar
fraser9764
dont know about discs, i doubt it, im using focus rs discs with my brembos. are they 330mm? im guessing the offset will be way out.
for brackets, i bought some 5/8 thick ally off ebay, made a thin steel template and made my own, was quite easy, although, i am having to re do mine this weekend, as the original brackets sat the caliper about 5mm too far out, was fine with my 17x8 comp mo's, but my new 17x8 tsw hocks dont fit so ive got to move the caliper in.
if you dont mind the outer 3mm of pad not touching the disc i could sell the old ones? mine are fiat coupe turbo brembos which im sure are the same.
Old Apr 3, 2011 | 07:40 AM
J.T's Avatar
J.T
Hi Discs very unlikely to fit as the 406 disc hub does not protrude the disc face which means fitting wheel spacers as well as custom made wheels to clear the caliper, on the 2 V6 coupes I had both had to have custom made wheels to clear the calipers due to lack of space.
Calipers should be ok though
Old Apr 4, 2011 | 12:03 PM
ram's Avatar
ram
Has a large member
Yeh looked into it and defo cant run the pug discs. but can get focus rs discs off ebay for about a ton
Will need new braided lines too as ive been told that the brembos use banjo fittings?
Fraser - what did you fit regarding brake hoses?
Yeh there the same brembos used on the pug coupe, certain alfa's, fiats and the focus RS.
If the price is right id prob have you old brackets (if thats what your offering?). however im not running comps now i have rondells. and the clearance on those is poor so reckon id prob have the same clearence issues your now having on your hocks.
Nov 1, 2015 06:53 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
locum8
Oct 1, 2015 01:50 PM
SMILER258
Sep 28, 2015 09:04 AM
