Tuning a Mk 1 focus RS
Old Apr 1, 2011 | 04:00 PM
RStony123's Avatar
RStony123
Default Tuning a Mk 1 focus RS
Hi
Can anybody advise where is a good place to get a mark 1 FRS tuned to around 350bhp and what would be required to get it to this power?
Any help is much appriciated
Tony
Old Apr 1, 2011 | 04:34 PM
JamboRS's Avatar
JamboRS
focus rs 1672
mods wise hybrid,exhaust,decat,manilfold,forge actuator,forge recirc,air to air intercooler(optional),gen 2 should see you running 350 at 22-24psi
Old Apr 1, 2011 | 06:04 PM
wootty's Avatar
wootty
"THE BLING MASTER"
budget for around £2500-£3000 for that lot.
Old Apr 1, 2011 | 06:12 PM
pani_k's Avatar
pani_k
PassionFORD Member
Are these reliable running this power on completely standard internals? Wouldn't ARP head studs and rod bolts be advised? And also iirc clutch would need changing at that sort of power.
Old Apr 1, 2011 | 06:18 PM
ST Turbo's Avatar
ST Turbo
What can standard internals with stand as it goes??
Old Apr 1, 2011 | 07:57 PM
JamboRS's Avatar
JamboRS
focus rs 1672
the frs' running 380 bhp on standard internals and standard clutch,just depends how you drive and how much pain you give it
Old Apr 2, 2011 | 09:34 AM
RStony123's Avatar
RStony123
Thanks for your help guys any ideas on the best company use?
Old Apr 2, 2011 | 06:47 PM
JamboRS's Avatar
JamboRS
focus rs 1672
join the rsoc and the new frsec site,you'd be better buying the bits and adding them yourself or contact demonpete from stanthorne cars http://www.stanthornecars.co.uk/ and he'll help you no bother.
turbo - guy on the above sites called johnfrs,he builds hybrids for these cars and there top notch
manifold - theres pd and jek,these are prob the best,then theres miltek and blueflame the best of the rest
actuator and dv007 recirc dumpvalve- get these from forge motorsport with a blue spring or if you want to run a boost controller yellow spring and yellow spring in the dump valve if your running blue spring in the act
exhaust- mongoose,miltek,blueflame or if your really flush a pd one
gen 2 - contact graham at car parts express http://www.carpartsexpress.co.uk/ he should be able to get you one of these
decat - again same as exhaust mongoose,miltek etc
air to air intercooler(optional,not needed unless car gets a doing) pro alloy,radtec,airtec,all pretty much the same
these mods should give you 350bhp,clutch may last it may not,options for them is ap paddle,ap organic or sachs racing clutch,carpartsexpress for these again
and youll need some decent brakes to stop.ap 6 pots or contact shins from above sites and he can get the ap 2 peice which alot of frs guys use
hope that helps
Old Apr 2, 2011 | 07:14 PM
Nick.W's Avatar
Nick.W
I'm seriously considering ditching my S1 for one of these.
With regards to the above mods to achieve 350 BHP what sort of mapping/ecu mods would have to be used?
Do Dream science/ Bluefin do a plug and play for this level of tune?
Old Apr 2, 2011 | 07:21 PM
UkChris023's Avatar
UkChris023
Im fairly sure puma speed do complete kits for these for the BHP you want and they fit it too for a charge as well IIRC
Old Apr 2, 2011 | 07:22 PM
Mark_'s Avatar
Mark_
can run on standard map, my mate ben had a johnfrs turbo and blue flame exhaust with decat with manifold and just reset the ecu after fitting, had the afr checked and all was good
Old Apr 2, 2011 | 07:25 PM
Mark_'s Avatar
Mark_
heres the car on the rollers, not sure if this was before of after the manifold was fitted but pretty sure he ended up with 360bhp
http://www.youtube.com/watch?v=MiZXG..._order&list=UL
Old Apr 2, 2011 | 07:45 PM
Nick.W's Avatar
Nick.W
Cool thats good to know.
Cool Vid too!
Old Apr 2, 2011 | 08:42 PM
me_again's Avatar
me_again
I would say that car had a MAP on it as at that power a FRS with bluefin or dreamscience would be on the limit of the fuelling system .
Old Apr 2, 2011 | 10:45 PM
JamboRS's Avatar
JamboRS
focus rs 1672
forgot to add map to my earlier post,bluefin,dreamscience or custom map whether it be unichip or msd remap these aswell which seems to get good results
you cant even run a standard map with just a decat,fuelling will be all over the place,map is first thing to mod imo
Old Apr 3, 2011 | 09:09 AM
Mark_'s Avatar
Mark_
i promise you the map hadnt been touched.
ill try and get him to post on here. he was still on the generic map.
Old Apr 3, 2011 | 09:21 AM
me_again's Avatar
me_again
Are ou sure the car didnt have a MAP on it when he bought it ?
Old Apr 3, 2011 | 09:26 AM
Mark_'s Avatar
Mark_
car was totaly standard when he bought it.
ive asked him too post up on here when he gets time so hopefully he will and give the full spec of the car.
he no longer owns it though.
he was a regular on the rsoc site.
Old Apr 3, 2011 | 09:27 AM
GribbiN's Avatar
GribbiN
Think what the lad is saying is the map didnt need to be customised (re-mapped) but the bluefin or which ever generic map worked fine with new mods after a ecu reset.
Old Apr 3, 2011 | 12:58 PM
JamboRS's Avatar
JamboRS
focus rs 1672
to make 360bhp it needs to have some sort of generic map or be remapped on the std ecu from someone like msd
having no map with a decat would throw up the eml and very much doubt it would make 360bhp on std map
Old Apr 3, 2011 | 08:51 PM
me_again's Avatar
me_again
As Jambo said even a decat would bring up eml as i had that problem with a sportscat and no MAP
Old Apr 4, 2011 | 07:50 PM
wootty's Avatar
wootty
"THE BLING MASTER"
i thought the std maf and std injectors max out at around 315.
Old Apr 12, 2011 | 09:04 PM
rstdave's Avatar
rstdave
The car WOULD have had a generic map on it (bluefin or whatever), not just a totally standard car......he may not have installed the map himself!
SMILER258
Sep 28, 2015 09:04 AM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Tank Mike
Sep 26, 2015 08:07 AM
RSBryden
Sep 6, 2015 08:39 PM
