Thermostat housing.. ??
Old Mar 27, 2011 | 09:22 AM
pee vee's Avatar
pee vee
Default Thermostat housing.. ??
Fukking things are useless. mine has started leaking a little bit
again.. brand new one 6 months ago.
Can an older style Zetec one be used? they are metal on the old escorts/fiestas ETC
anyone tried it with any success? they also would have the advantage of having a port in them for a temp sender for aftermarket gauges.
Old Mar 27, 2011 | 10:07 AM
thebigmacmoomin's Avatar
thebigmacmoomin
Wont the part still be under warrenty if its only 6 months old?
Old Mar 27, 2011 | 11:18 AM
btcc93's Avatar
btcc93
The old silvertop housing has extra sensor holes that need a suitable size bolt fitted to blank them off, otherwise they are fine to use, I did it as a tempory fix on my sons blacktop engined Focus a year ago and he has never changed back.
Old Mar 27, 2011 | 02:17 PM
bullsrs's Avatar
bullsrs
my st170 was leaking from the clip in plug on the bottom of the housing is it not just this thats leaking on yours?cost just under £10, i only noticed it cos there was water staining on the bellhousing of the clutch, also earlier zetecs were plastic too, not sure bout the very first ones though but i know my 97 model escorts were plastic and have different sized sensors on top with different connectors compared to later escorts but the focus may all be the same, good luck with it mate
Old Mar 27, 2011 | 03:02 PM
RichieST's Avatar
RichieST
Is it cracked phallis or just the seal that's gone? I'd definately take it back if it's only 6 months old, however I guess Ford will use the approaach that if they didn't fit the part then they won't cover it...
Old Mar 28, 2011 | 02:33 PM
CarParts Express's Avatar
CarParts Express
did u change the header tank cap at the same time as when they fault and dont release pressure this is what causes the housings to leak
Old Mar 28, 2011 | 02:46 PM
martysmartie's Avatar
martysmartie
You can buy alloy items to replace the plastic ones for this reason.
Martin
Old Mar 28, 2011 | 03:12 PM
pee vee's Avatar
pee vee
Martin
You can, but they are £300 !
Carparts: no i didnt replace the cap, I will try that too then!
cheers!
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Chas
Oct 5, 2015 07:13 PM
The Enigma
Sep 29, 2015 10:31 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
