Water pump for Focus rs mk1
Old Mar 24, 2011 | 01:36 PM
ogx's Avatar
ogx
Default Water pump for Focus rs mk1
Hi!
I need a water pump ford focus rs mk1,genuine ford is too expensive 460 pounds,what recomend me? one in ggr,woodford garaje,matt lewis...,or genuine?
Thanks mates!
Old Mar 24, 2011 | 04:15 PM
phil_focus's Avatar
phil_focus
fuck me thats dear!!
in what way do they differ to a normal 1.8/2l focus one? can't really imagin them being any different unless theres a take off for the water cooled turbo???
maybe you could modify a standard one. of course though i might be competely wrong.
anyone else got any ideas?
Old Mar 24, 2011 | 04:20 PM
Gaz 88's Avatar
Gaz 88
The rs ones has diffrent flow rates and no other is high enought for the rs so you will need a genuine one unless you want to risk your engine!
http://www.part-box.com/ford-focus-r...p-p-15112.html
cheapest place above mate
Old Mar 24, 2011 | 04:23 PM
phil_focus's Avatar
phil_focus
ah i see, better off with genuine then.
Old Mar 24, 2011 | 04:26 PM
Gaz 88's Avatar
Gaz 88
yer i wouldnt risk anything else!
Old Mar 25, 2011 | 10:24 AM
Convert to electric water pump ?
Old Mar 25, 2011 | 05:00 PM
CarParts Express's Avatar
CarParts Express
http://www.carpartsexpress.co.uk/pro...StartRecord=10
i have one in stock for next day delivery
Thanks
Old Mar 25, 2011 | 05:12 PM
justin2's Avatar
justin2
ive had a 1.8 and rs waterpump next to each other and personally dont believe theres a difference to be sure speak to Ian Howell at area six hes built loads of high power zetec turbos and will tell you for sure!
Old Mar 25, 2011 | 05:53 PM
wibbler's Avatar
wibbler
The RS pump is visibly bigger than a standard one, on an RS things like the PAS pump are mounted on spacers to clear the water pump casing.
Not a cheap part but there aren't any real alternatives, comes with buying something needing low-volume unique parts.
Old Mar 26, 2011 | 03:11 PM
ogx's Avatar
ogx
Thanks
Really genuine,or copy?
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Oct 9, 2015 07:38 PM
cameron2
Aug 25, 2015 07:18 AM
MARKYMARKONE
Aug 20, 2015 12:55 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
