fiesta zetec turbo manifold "luca" over gearbox
hi for sale is a mk3 fiesta zetec turbo exhaust manifold exactly the same as the one i built for luca's engine (yes i built it not jkm)and running very well. it looks the biz and does the biz. the manifold is a over the gearbox box type which will relocate the turbo to sit above the gearbox which has the advantages of moving all the heat sources away from being in front of the radiator and intercooler.
the manifold is the finest quailty and built using the best materials in this price range , yes you could do 321 stainless but at £80 a meter the price has just doubled and your into £2000 for a manifold to be totally honest ive never had any issues with the materials with engines running 400/500bhp provern on the drag strip and track.
the manifold has equal lenght headers and is made from 304 stainless steel with all bends being mandrel so theres no loss of exhaust gas speed , also helping with exhaust gas speed and scavageing is the race 4-1 merge collector made to the highest standards with the highest welding also.
the zetec flange is made from 10mm thick stainless steel to ensure no corrision . the manifold has been fully tig welded and back purged again to ensure that theres no weld protruding on the inside of the pipe causing exhaust gas speed to be slowed down so the inside of the pipe is as smooth as the outside.
as stated above this will only fit a mk3 fiesta (maybe mk6) i can give measurements if you require .
the manifold is £550 upto the end of the collector and can be finished for another £100 , ie any size turbo flange in 13mm stainless steel , 2 inch end pipes with or without external wastegate take off, again everthing being tig welded and back purged.
this will save you £100 and theres only one avaliable
a very famous passionford engine bay
a few pictures of the one for sale
cheers paul
cheers paul
Billy_RS
16
Oct 11, 2025 09:41 PM
Cameron
14
Aug 9, 2015 06:28 AM
, you bummer
