using water?
Old Mar 22, 2011 | 05:45 PM
bangerboy33's Avatar
bangerboy33
Default using water?
Why do I have to keep topping up my water every couple of days there is no hose leaks cause I put cardboard underneath the front but the header tank is empty every couple of days checked head gasket and done a pressure test and showing no leaks its a cvh by the way?
Old Mar 22, 2011 | 06:11 PM
RichieST's Avatar
RichieST
Do a pressure test of the system.
Old Mar 22, 2011 | 06:24 PM
martysmartie's Avatar
martysmartie
Maybe heater matrix?
Martin
Old Mar 22, 2011 | 08:11 PM
Pressure test won't definitively show a problem, even if there is, it's a good guide that's all but not 100%.
Do a sniff test on the expansion tank, as above check the carpets as well.
Old Mar 22, 2011 | 08:58 PM
bangerboy33
Done it all its really pi**ing me off should b able to smell it its running pure antifreeze good job I have a unlimited supply!
Old Mar 22, 2011 | 09:02 PM
martysmartie
Well it's either leaking it or it's getting into the combustion chambers, it may be a small split perhaps and it's only noticable when running.
Martin
Old Mar 22, 2011 | 09:33 PM
MO' BENT RIMS's Avatar
MO' BENT RIMS
mate this is what to do.. get a mate to sit in it and drive it on a ramp then get him to run it and u look underneath u will see exactly where its coming from if there a leak otherwise it could be a heater matrix or something very minor
Old Mar 22, 2011 | 09:34 PM
Sp3no's Avatar
Sp3no
Maybe it only leaks when up to temperature. Focus thermostats as an example are terrible for leaking but you dont notice as its only when the cars running
MO' BENT RIMS
check underneath the rad and front mount.
Old Mar 22, 2011 | 10:02 PM
GVK.'s Avatar
GVK.
Tried header tank cap?
Does it start cleanly first time you start it? Or does it misfire on start up then run clean? My old Series 2 used to misfire on start up, slight leak on head gasket, water in one of the bores, took plugs out one was a nice greeny/blue colour.
Old Mar 22, 2011 | 11:20 PM
bangerboy33
Thanks for all ya replies few things to try there
Old Mar 26, 2011 | 02:48 AM
bangerboy33
Still losing water seems gonna have to put up with it thanks for all ya suggestions though
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
