Misfire when hard on boost help!!
Old Mar 19, 2011 | 08:49 PM
MO' BENT RIMS's Avatar
MO' BENT RIMS
Default Misfire when hard on boost help!!
LADS PLEASE I NEED HELP . when i put the foot down on my rs turbo its a 2litre zetec turbo engine and when i floor it it comes on boost hard and then just pops and misfires etc / its perfect on normal driving but does it when its about 200rpm away from the reline so it boosts up and then just misfires ...could it be the plugs or something???? i aint no mechanic please help
Old Mar 19, 2011 | 09:09 PM
MO' BENT RIMS
Old Mar 20, 2011 | 07:41 PM
Churtz's Avatar
Churtz
What management is it running? What boost are you running?
Initial thoughts would be spark timing under higher boost levels.
Matt
Old Mar 20, 2011 | 11:02 PM
martysmartie's Avatar
martysmartie
What plugs are you running and what are they gapped at? Try closing the plug gaps a little.
Martin
Old Mar 21, 2011 | 07:46 PM
MO' BENT RIMS
omex 600 i had the sensors checked on a laptop to see if they all work they all seem to be perfect. i changed the plugs and it still does the same thing .. i run the coil pack on the plugs conversion so im changing them tomorow and then see if thats cured.... could it be the fuel filter? thanks for your help lads i appreciate it
Old Mar 21, 2011 | 08:19 PM
Alvyn's Avatar
Alvyn
r u using the correct plugs/gaps?? and also could be a fueling prob, so suggest get it to a pro and save yourself the headache!
Old Mar 22, 2011 | 08:17 AM
martysmartie
Yes fuel filter could also cause this as it leads to fuel starvation, so many people seem to think it's a non servicable item!
Martin
Old Mar 22, 2011 | 08:20 PM
MO' BENT RIMS
ok i changed the coil packs today and still have the same problem so its leading me to think its the fuel filter or could it be the maf??? not suire what a maf is someone told m,e it could be that?? please help
Old Mar 22, 2011 | 08:21 PM
MO' BENT RIMS
could it be anything else
Old Mar 22, 2011 | 08:37 PM
boaby's Avatar
boaby
Miester
fuel pump?
Old Mar 22, 2011 | 08:49 PM
MO' BENT RIMS
it had a pump about a few months ago and was new and a racing cossie pump and its buzzing like normal ... could it be on its way out?
Old Mar 22, 2011 | 08:51 PM
martysmartie
MAF (Mass Airflow Sensor) is a wire gauze that works on a hot wire principle, it has the ability to measure air flow as well as temperature, usually I think the general consensus is that if the car struggles above 4K the MAF could be faulty (Usually it just requires cleaning) I think when there unplugged if the car performs better then it confirms this.
I don't think it is in your case however, the fact it only happens at high RPM would suggest ignition or fuel to me.
Martin
Old Mar 22, 2011 | 09:23 PM
MO' BENT RIMS
thanks mate ill try a new pump then and filter and see if its cured
Old Mar 22, 2011 | 09:30 PM
Churtz's Avatar
Churtz
Near the middle of your thread you stated that you're running omex..are you sure you're using a MAF and not a MAP? as said before I would look to ignition. Fuel would be more of a gradual decrease of power as the boost rises, rather than a sudden loss.
Matt
Old Mar 22, 2011 | 09:49 PM
wayne dowling's Avatar
wayne dowling
It could be ht leads braking down under load
Old Mar 22, 2011 | 10:03 PM
BRAM's Avatar
BRAM
He hasnt got ht leads i dont think mate, im sure he has got coil on plug.
Old Mar 22, 2011 | 10:22 PM
MO' BENT RIMS
yeah i have coil on plug.. and im using omex so it must be a map and not a maf ... anything i should change?
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
